I don’t think so. I have like 20 lb’s in like 20 different examples, of nickel stripping. This is the first I’ve had that I felt suspicious of.
Could it just be that they skipped annealing?
If you’re that set on having an ironclad (or nickel clad?) answer, I would recommend having a professional metallurgical analysis done. Usually cost about $20-50 for a sample, and they will use an XRF gun to tell you exactly what’s in it.
Just make sure to sand the surface to make sure there’s no plating to interfere - XRF only measures a couple micrometers deep.
Or you could just take any high-speed abrasive implement (dremel, angle grinder, bench grinder) to it, and know in seconds. But that’s just me.
If one of these China companies can find an alloy that costs a tiny bit less per roll than nickel then they will use a boatload of low cost labor to test the different alloys and find out which is best. They will then sell it at nickel prices, recoup their investment quickly, and go on to make a ton of money.
It’s like what some battery counterfeiters do when faking the Murata VTC5A cell. They’ll buy genuine VTC5’s, wash off the printing on the metal can, reprint them as VTC5A’s, rewrap them, and still make a boatload of money.
Economy of scale and practically free labor makes a lot of things we think is nuts actually quite profitable.
Know any people that can do that?
Ha.
Okay, I’m definitely doing this. Thanks.
I will try the spark test, first, though.
edit: no sparks, not even in the dark using abrasive cutoff wheels at max rpm.
Maybe I’ve missed - just how much $/lb of Nickel is in this batch?
30 feet of 50mm. I think I had trouble finding 50mm from the known good suppliers when I looked. I’d like to know that I can purchase it in the future without having to worry.
I think it’s like 2 lb’s/ $56.
Purchasing nickel always involves worry.
Suppliers come and go all the time and sometimes even get burned themselves.
Pretty sure 2 years ago a well known good supplier ended up getting nickel plated steel himself from his supplier, didn’t realize, and sent out a bunch.
Pretty much have to worry and test with each batch you buy if you really want to be sure.
Jeez.
Hello all! Thanks to everyone, this forum is the bomb. Finally have most everything needed including some time to start my first build. Without this forum my board would go backwards, wheels falling off, me cracking open my melon and the board bursting into a fireball. After reading the this forum/topics for hours I am confident this will not happen so thanks a million!
I bought an MBS DWII complete a while ago, keeping the Matrix on it. I am looking to change the front truck/deck tip angle from the stock 30’ to the recommended 35’ angle so I bought Khiro 5’ angle risers.
Simple as this sounds it has led me to a bunch of questions.
#1 - Will this angle riser take the abuse of NYC streets and some off road riding?
#2 - The DWII came with front and back 6mm rubber risers for some dampening. I would like to keep these on for that reason-dampening. Should the 5’ angle riser be mounted - deck, rubber riser, 5’angle riser then hanger or option #2 deck, 5’ angle riser, rubber riser, hanger?
#3 - Installing this angle riser in the front will raise the height of the deck around 10mm, I did not measure exact yet.
I don’t want the front of the deck to be higher then the back.
Should I install a 5’ angle riser in the back of the deck also? That would bring the back to 35’ also but I am not looking for speed wobbles. Would it be better instead to install an appropriate height flat solid riser in the back of the board to get the f & back the same height?
Thanks in advance!
It can. I had angle riser like those for my MTB build. The rest I can’t really answer because I don’t have those trucks. You will not get speed wobbles from the angle riser (I didn’t when I had it before I got a 35° angle deck). You will get them if your trucks are mainly spring trucks (if barrel like, meaning like bushings, you good).
Edit:
Do not use the riser pads unless you have no clearance space for your battery. But if you don’t have it, it’s deck, riser pad, then angle pads and then the trucks (note, your screw has to be extremely long for this to work).
I appreciate it. I am not sure if increasing the angle in the back is a good idea. Installing the riser in the front is kinda funky because the metal hanger surface to the deck is much larger then the size/width of the angle riser.
You can ask yourself, “do I want to have a better turning radius, or less?” If you want more, add the angle riser to the back as well. And yeah, that riser is made more odd for a skateboard. Mountain boards are a bit longer. You can tell by putting the two risers together.
Still a ways off from finishing but I don’t think I will be looking for more turning. The reason I was thinking of putting the riser in the back is because I don’t want the front of the board to be higher then the back. Once I measure the height of the front with the angle riser I think I will just get a flat riser/non angled for the rear just to keep the deck height even. Thanks!
No problem.
