I think you mean spacers like these:
Thanks! I know others said I didn’t provide enough info; sorry about that. This is what I was looking for
Anyone have recommendations for cushy, dense foam to support batteries?
I like neoprene foam for that. It’s generally closed cell, so it’s fairly dense, and will squish flat under enough prolonged force to conform to the shape of the battery.
So if a 10s bms has only 10 balance leads then they only go to the positves …and it uses the b- instead of the 11th balance wire which is not there? Its a bestech d124
Yes
B0 - B10 starts at 0V and goes to 42V
B1 - B10 starts at 4.2V and goes to 42V
B0 = B-
Not all BMS have B0
Do you think this is okay? I want to get it over the bell sanction because it has more ventilation and I get too hot. They are the same price where I live. I don’t go above 25mph. I’d get a fox proframe but it’s 3x the price so I can’t afford it.
If its + 100° and your rocking a full face it gets really hot when you stop. This mtb helmet should be fine under 25mph…any faster and i would get something with a higher rating. Usually there are (2)two ratings. One for highspeed and one for low speed.
I can’t help but wonder what the rational is when battery builders make their series connections with nickel on nickel welds, i.e. they weld their p-groups first. Why doesn’t everyone make their series connections first, and their parallel connections last? I just happen to think your strongest welds should be your series connections. Of course this only applies to packs with doubled up nickel. Am I wrong?
For what it’s worth, the proframe is very much worth it imo.
I do however fucking hate FOX as a company though and they don’t have any meaningful discount for crashed helmet replacement.
Is there any sort of organization going for a group buy of p42a’s? I noticed they are back in stock on 18650batterystore, and I found an old post from march that was locked, but haven’t seen anything since then.
I believe the group buy has already be done
are regular motors waterproof? can i jetspray my board
If you’re not using the sensors, they kinda are, yes.
If you are using the sensors and you haven’t waterproofed the sensor board, then no.
i mean the enclosure is sealed pretty good, im more worried about everything outside it
I am only talking about the BLDC motors, to be clear. The enclosure obviously depends on how you did it.
Also if you assembled the motors this way, they will resist water much more.
i mean water is guaranteed to enter the holes if i spray it, i just wonder whether that would break them or make them rust
