confirm…you will lose your nuts on the run like this
Acetone
just squeeze the new loc tite on there
thats the way I do it.
If its bolted in again you dont have to see the mess anymore
Yup, same.
Been running my meepo hub sleeve screws without loctite at all lol. Haven’t moved a mm.
Oh but be patient, them Meepo hubs m3 screws are pretty short. If one comes lose its pretty quick that you lose them all. Friend of mine rides a meepo mini and I exchanged the screws against longer once for him.
U can use screws up to 16mm length.
I’ve replaced all with proper hard screws and not some weak ass chinesium screws that strip.
LMAO, sorry hahahaha, my fault
I feel like a giant dumb ass (probably because I am,) but I can’t figure out how to setup a power button on my Vesc 6 mkiii. I’ve tried momentary and latching to no avail. Any tips are super appreciated! Thanks in advance!
What pins are you connecting them to? I think there’s a setting that has to be enabled in VESC Tool, am I right about that @Trampa?
I think it’s this setting.
dis
e: u need a mom switch
What’s your price for a loop key (including shipping to Sweden)? Or to solder connectors to an antispark?
If you want an 8AWG one I can solder it together for £15 or I have premade 12AWG (Does about 70 amps given how short the bridge is) for £10
How’s the shipping to Sweden now with brexit and all that? Is it plenty worse? I will investigate the alternatives and see what the best option is, but I appreciate your help. I might choose you if the other options turn out to be too time consuming or too costly
I agree with the others though that maybe it’s a sign to get a better soldering iron. But yeah, I will weigh the options
I’d also reccomend a soldering iron
Shipping isnt too expensive but it can take quite a long time, sometimes well over a week
How do you bypass a common port BMS?
looks good. one thing I’d suggest is adding 2 extra screws for each segment that way if you loose a screw is doesn’t instantly separate from the board. might also be a good idea to make yourself some tpu washers to sit in-between the screw and the enclosure. I did this for my petg enclosure and its lasted my like 6 months.
Thanks man!
Yes it can.
