With fresh bearings on the geardrive about 16-17wh/km at 40psi in the bergs.
After i hit a puddle or it starts raining a bit about 19-21wh/km until i change bearings.
Btw, had, thankfully.
Now i’m on moon drives with 9 inch mudpluggers, transferred the battery over and from the previous 30-35km range i now get about 25, 30 if i’m gentle. Although on the street keeping up with cars consumes 33wh/km and brings my range to 20km lol
The positive ramping time is from the current position, let’s just assume neutral for simplicity, to the new value you input through throttle. Both negative or positive.
Negative ramping time is from accelerating or braking to the neutral when you let go of the throttle.
Let’s say you have 3s positive 1s negative throttle.
You’re going along a street and need to press full brakes.
It will take 3s to gradually increase brakes up to the maximum in this occasion.
Then you start accelerating to maximum immediately. It will now take 1,5 seconds to stop braking and 1,5 seconds to reach full acceleration.
Then you let go of the throttle to free roll. It will take 1 second to gradually release all power from the wheels.
I will be using berg tyres, hopefully untill timo it’s back!!
I’m going for pneumies for comfort so im ready to sacrifice range… If I need more range I would just switch to my 115mm and call it a day (if I end up not selling them)
Oh shoot! That actually makes sense; the negative ramping time message Ben shared actually mentions it being from full output (acceleration OR braking) back to zero.
I’ll test some more tomorrow to check for myself. If that’s true, then what Brian said was the correct advice for OP who wanted a slower return to neutral. (I misread it at first and thought he was talking about positive ramping time, my bad! )
I just increased my “Negative Ramping Time” from the stock 0.2 seconds to 1.0 second and went on a 25 mile ride. When I am going at speed and I release the throttle, it takes 1 second to ramp down my acceleration to free rolling. It had no effect on my braking. If I am moving at speed and press the brakes, they react immediately with no delay.
