the BKB inward mount might fit, but BKB uses the caliber profile, not sure how perfectly they fit together.
Cheers @frame.b022. Yeah I fucked up and ordered the V7 mount but it’s huge and space is limited as it is for my short board build.
the v7 mount is outward mount, but i guess it doesn’t work that well with a short board build
I thought it could be an inward mount too but looks like I got that wrong as well haha. Anyway it’s way too big so my plans need to change
Thank you
I will be stocking about 100 meters roll
i can choose thickness as well but it looks like most the time only 0.2 available
i guess 70mm can always trim to 65 if needed
is there any need for 100mm or 200mm
or 70mm seems to be sweat spot
thanks
For me 70mm is the preference but maybe for others it will vary
. Thickness’ would be interesting I’m assuming it would provide more insulation? Might be useful for using bellow series connections and or to bridge BMS cables. How much would you sell for ?
Hi all,
Is there anyone London, UK based that could rent/let me borrow their kweld/malectrics/decent-high spec spot welder for 0.2mm nickel (and lipos to use it)?
Ideally to use it in the next 2-3 weeks for a period of 1-2 weeks?
for the forum probably i could do 3 £/m
ebay or other platforms close to competition
Nice sounds good!
Did you see where I put mine on my hummie build? My charge port has not hit anything so far
I would place those last, after everything else in your enclosure has it’s permanent home. That way you are not running into issues trying to fit things later.
These is the last step, everything is ready to go!
Ok thanks! I’ll take a look
That’s probably JST-PH connectors with 2mm pitch since that’s what Trampa (and most all other vesc’s) use
yeah, ive had confirmation that it doesn’t work - too large
I haven’t really gotten the newer models.
Noob question for these trucks:
Do I need to add dampas in the springs or go for barrels? I took a test ride on these and it was very bouncy. It was very fun to ride, but I think these are missing something.
I have springs and dampas on my channels (250lbs) and still too floppy, so everyone says to go barrels.
