@Geo_Engineering_FTW yup those cables should work for the mini foc, you need to remove the +5V and GND cables, and swap one of the connectors so that the cables are crossed.
No need to cut the cables, you can remove them with a tiny flathead screwdriver
The way they come it would connect esc1 CH to esc2 CL, you want CH-CH and CL-CL
Oh, thats kinda strange. In theory lower kv means more torque / amp. I ask anubis whether he will have 190kv in the near future. If not, should I go for 140kv 6384 flipsky, or 192kv SK3 6374? Tbh I am still leaning towards the 6384 FS, mainly because that would mean I have a keywayed shaft. There really isn’t any other option for me, because it has to be max 100€ shipped. And because of the gearing, to avoid belt skip, I think a lower kv would be more appropiate. 15T is kind of on the edge of skipping, while 20T will for sure not skip when set up well.
no, it wouldn’t work. such a long battery with nickel series connection won’t work on any deck. just don’t. you will have broken nickel, probably sooner than later.
So I did buy a Sunko Spot welder on Amazon even though I’ve heard mix feedback.
Having a look a came across A cheaper portable one but it is rated up to 0.12mm I wondered if anyone has used it or something similar? How good is it? Is it possible to do 0.2mm welds?
Battery from tinp in a hummie here. 12s4p p42a. Do not use nickel to connect the pgroups unless it’s bended 90° to either the face or the back of the pack. It does not flex much but it’s more than enough to create some odd wrinkles in straight nickel and start rubbing on cell wrapping.
Mine uses 14awg wires to connect pgroups and i have been pulling peaks of 100A from it @Halbj613
May not be the case at 12 of 10S both are only rated at 12S but the slightly bigger one handles it better. I have heard reports of the 90kv and 120kv motors burning out at 18S.
