Any recommendations on a 10s charger?
Thinking 5A or 6A for a 10s4p P42A pack.
I’ve seen the super cheap $26 YZPower charger and the pricier $100 Luna adjustable.
Im going to advise you run PPM over UART, it is a flipsky product and should be treated as such and from what I understand there are more protections on the PPM side of VESC firmware in cases of potentiometer failure among other things. If you’re at all capable with a soldering iron its a 10 minute operation.
Housing? For what?
receiver to vesc, no?
I thought about running ppm but it seemed difficult so i just ran uart
Yes, are you talking about the housing for the pins on the vesc end?
why do i need to change the housing?
V4 is 7pin uart, V6 is 8pin uart, unless u r confident in matching the wires to pin with a mismatch plug type, or else i would highly recommend just swap to a 8pin housing
Oh, I just plugged it in anyways and it seemed to fit lol
7pin can plug directly into 8pin with no problem, just make sure the wires are going into the correct pins
Okay, so switch the tx and rx, and check the other pins, thanks
Look on YouTube for changing JST pins. You pry a tiny piece of plastic up with a knife point and you can move the wires super easy.
how much is too much startup boost?
What’s this common semi flexible material called they use for moulding of USB plugs and other various connectors?
You mean Sugru?
have tourqboards 218 trucks, can somebody please tell me what size are the bearings are cant find my digi Vernier gauge
thank you
the truck axle is 8mm, normally we use 608 bearing, but depending on what wheels / hub u have, it could change
thanks are they both the same front and rears?
most case front and back use the same size
