unplug and hide away, keeping them soldered doesn’t really change anything except if u want to sell those motors in the future and the buyer might need those sensors
that is why i do appreciate the time he put into replying
thank you
I tend to learn/research in excess before i attempt any project
this is perfect — exactly what i was looking for – bullet points
thnx
Does anyone know what could be causing this? I’ve tried retightening all of the fasteners already.
Drop a tiny piece of shaved soap into the pivot cup before you reinstall the truck hanger.
The solid kind of soap, not liquid. Paraffin or a tiny candle shaving can also work.
Doesn’t seem to have worked
Does more using more soap shavings work better?
Probably not
Maybe skating on it though will work them in and get it quieter.
If it is the bushings making these noises, try rubbing candle wax over all faces which have contact to each other. This solved it for me in the past.
Any thoughts on how to get the belt to stop walking? From my understanding this is caused due to a misalignment of either the motor mount or maybe even the set screws torque?
For reference I’m using matrix II trucks.
The pulleys I have don’t have a flange so the belt will walk all the way to the wheel and if I carve the belt will pop off the motor pulley.
Any idea where I can get one of these 15 pin connectors? JST 15 pin, 2.54mm pitch.
Lol no clue, but if you find out make sure to let us know
10000th post! WOOOOOOOT!
Those are for JST EH (2.54mm pitch).
not sure where to put this question, so i will do it here
anyone know what’s up with those chinese brand lately? some of their website just disappeared overnight, EOVAN / stakboard / boundmotor…etc, just to name a few
the “bigger” brand like meepo / exway…etc still exist, just those “not-so-well-known” brand vanished for some reason.
@BOUNDMOTOR @ReplyRetricted
i assume the webhoster was down or something?
boundmotor and eovan websites work for me.
so its my problem then, time to bring out the VPN and VMs
I’m after a deck that’s short and fat. And yes I said DECK haha.
In the 31 to 34 inch range with a kicktail is ideal and wide enough to accommodate TB 218mm trucks. Wheel arches be good. The Loaded Omakase or Coyote are options I’m considering but not sure if wide enough
Tayto
Kicktail on the Tayto sucks.
I got this one
Try the 30.43" Powell-Peralta Bones Brigade Mike McGill Skull & Snake Series 10 Reissue as seen on the Blue One
The one with the “cheeks” in the front, not the smooth round nose version.
With a wheel well mod
i got no other shortboard to compare it with, but it seems to work just fine…for me…for now…i guess
