Fantastic, I won’t connect them
Is there a large difference in torque between different brand 6374 motors? I just bought SK8s and have read a few times they have less torque than other brands?
I can’t seem to find any solid information.
No I didn’t remove it. I have another mini coming from Amazon. They have the vanpro ones for $16 right now.
I read up on and ordered an Alien Power Systems remote last night. I like trigger transmitters so it seems like the way to go.
Ill try the new mini remote while I’m waiting on the APS remote.
I have 2 6374 flipsky motors (both unused) and one of them is really hard to rotate compared to the other, will I be fine if I put it on my board and program the vesc?
Try doing the hand motor test and see if there’s anything up
thank you, just finished hand testing it everything felt good so ig i’ll test it with the vesc tool and if it doesn’t work well gotta get another one
Has anyone tried this?? Are they shit?
€ 198,01 40%OFF | Juego de Motor de buje 105LMH de alta recomendado, negro/rojo (Motor de buje + rueda delantera + camiones)
so how do i check the voltage coming out of my charge port without shorting it
take a plug off something that fits in and use the wires coming off it.
my bet is loose wire
just lick it
its the dingle tingle test…
so are you saying cut of the female end of the barrel plug and check the voltage from that?
I think you should skip this step as it has no chance of fixing anything.
You should get the board apart, battery out, and unwrap it.
oh my, not the unwrapping. sry i just scared of messing with that stuff but i will take it apart
open the board yeah. dont unpack the battery.
if its internal , @Skyart will probably offer to fix it. He rightfully takes a lot of pride in his work.
okay, i have a theory. i bought the enclosures from ownboard and it already had the charge port, so i think it could be one of the wires from the charge port
Whats up pal? Something up with your pack?
Empirically, yes. Turnigy sk8 motors to me feel really weak. I don’t know the numbers. If you want a motor that feels really really strong, run a TB6380 at 90A motor max.
not sure yet i haven’t been able to open up because of halloween. i think it may have to do with the charge port
Ya, I got those hub, but mine are from boundmotor, should be same source tho
Interesting. If you were to put your best guess on it, as a percentage (at the same Kv) what are we talking 80%? Less…?
I wonder why, at the same Kv, amps, volts etc you could have such a noticeable difference.
