I think it kind of comes down to preference. Assuming you’re running two individual vescs, a y split should provide some redundancy if a vesc fails. In other words, a y split will let you ride home, while a canbus won’t (since if one fails, they both shut down afaik). Downside of y split is that it’s a little more work to set up imo, and you don’t get goodies like traction control (only through CAN; also afaik. Also I feel like there are a few other features CAN has that won’t be possible with a y split. Though I think I’m wrong ).
I’m assuming Metr isn’t really that different at its core (that’s its just a fancy bt module) and will work like any bt module and on a slave vesc.
Can’t setup both vescs on y-ppm, no traction control, no fault check for both, no telemetry, no smart reverse that is synchronized, actually no sync in general
Can use some input everything was going alright I did 10 miles the first day top speed of 37mph and the rode the next day for 1 mile everything was fine went to change my settings and everything freaked out and appeared to go to factory default and my motors now went in reverse with no power like 3mph tops
I would also not use the mobile interface for anything except a Bluetooth to TCP forwarder. Editing the settings on a desktop is like, ten times better or more.
You’re going to have to start over and redo all your motor detection and everything, most likely. Don’t forget to set “Duty Cycle Current Limit Start” to 85% and “Fault Stop Time” to 85ms in the advanced tab.
Ahh i was using the app for everything and it sucks and didn’t have alot of the settings that you told me to use also just found out that vesc tool 5. Works with unity should I use that over the unity one 0
is there a guide/notes/thread on understanding amps/volts/ mAh…all the elctrical stuff in terms of battery/motor/esc/bms configuration. Ive left it way too long in learning what these things mean and practically have NO clue. did look on the battery builders forum, but it’s not the sort of thing im after
I’m pretty noob too about this topic and before ordering the first parts of my build I ve read a lot of blogs and YouTube videos on electricity but this picture sums it all up
Amps = torque (how hard motor pulls) and heat, on every component!
Volts = how fast the motor spins, up to components rated limits!
Ohms can be generally ignored in setting up an electric skateboard, since it’s a property of batteries, motors, and wiring. All of which can’t generally be changed or are negligible in case of wires
Bonus:
Watts: volts times amps!
More volts, less amps for the same power, more efficient since everything generates less heat (except motors, they still pull those amps when starting up)
Now, an interesting quirk of vesc and motors is that at low speed, vesc can pull 1 amp at 50 volts from battery and deliver to the motors 50 amps at 1 volt. Ignoring losses, that’s 50W in, 50W out to the motors.
At 1 volt, motors will spin very slowly but have a very strong torque, which is necessary for starting up, then vesc will gradually pull more amps from the battery at the same voltage and deliver more volts to the motor as you speed up
ok, so if my motors are 85 amps and my ESC is 80 amps, then my motors outstrip the esc’s ability to push them to fullest.
how do i calculate the amps of my battery that will be 12s4p using 30q cells (im guessing it’s neccesary to work out the amps (continuous?) of my battery?
ESC ratings are generally battery amps, not motor, so the 2 numbers don’t compare directly.
Those rating are pretty wishy-washy anyways.
Your motors can run at higher amps than battery amps because of lower voltage.
Volts and amps don’t have to match on the 2 sides, only power does (minus the losses in between).
So in your case, there’s no bottleneck. You will push your motors to the max (amps aka torque), just not at higher speeds (aka duty cycle, aka voltage).
Battery max amps = cell max amps * p_count
30Q is 20 amp max, so your pack would be 80a etc.
You set motor max to the maximum they can handle (or more. Cold is coming anyway. Worse they can do is start cogging before they eventually burn out)
Also 99% of the mosfets, starting from 4.xx versions, are 150A rated
Your bottleneck here is the battery. They sag a lot even at 15 amps each so i wouldn’t go much further than that.
At top speed, assuming no battery sag and that you’re using a dual motor/controller (also ignoring the 95% duty cycle and rounding it to 100%), your vescs pull each 50v and 30 amps from the battery and deliver to the motors 50V 30 amps.
Now, if you had an overkill battery, you could pull 50v and 80 amps (esc rating limited) and deliver that to the motors, but i can say for sure that ~40 motor amps/side is more than enough for the average guy passing 50-60km/hr
Thanks. It all seems very abstract, but I guess once I have to program the ESC and input all the values, it’ll make more sense. Can I like download some sort of esc software tool to practice on?
So basically my Maker X MIni Plus, which is 80A (each motor) totalling 160A, will not even have half of it’s potential to be exploited because of the battery?
ah this is helpful, so it’s the P-count that determines the max battery amps. so, for 30q at 4p it’s (like you say) 80a, 5p = 100A, 6p =120a etc etc…so with my ESC maxing at 160A i could get up to 8p. thanks, seems clearer. so the higher the P_count the more amps im feeding to my motors…which would result in…higher speeds*?
…and just t add another question - so youve mentioned P_groups increasing torque, but what about S_groups, what does that do? (at this stage in my build, S_group could be upped to 13 (though my esc may not able to run that…would have to check - just checked: it doesn’t)
*wrong - just more torque, if understood correctly
