I’m running Trampa superstars on mine with normal skate bearings and the offset bearing spacer. @ZachTetra is running MBS hubs in some sort of configuration.
Your other option is not gluing in the axles and running 10mm shoulder bolts.
We discussed some options in a thread I started here: Trampa wheels on Boardnamics 270 Hangers
I have MBS Rockstar II hubs, 16100-2RS bearings, Trampa Urban Tread tubes and tires, Boardnamics BN270 trucks and mounts, M10 spacers, and 80mm * 10mm M8 shoulder bolts
Hey guys,
to start I live in New Zealand.
Ive just purchased a Trampa pro belt with a 2020 monster box. I didnt realize it didnt come with a battery but Ive decided to tackle the issue myself. Ive seen quite a few people recommend Li-Ion Batterys and I think thats the route id like to go.
I am looking for best range. I will be riding off road a lot and doing jumps.
Trampa has two batteries recommended on their site but theyre Lipo. Any help here would be greatly appreciated as I am very new to this.
Im sure this has been answered already, so if someone can point me in the right direction that would be great. but a couple questions before I head to bed.
What are the differences in KV’s for motors.
Is there a specific kv limit on @3DServisas SS Mini Helical Gear Drive V4 gear drive?
About to order some Maytech 6374 but not sure if I should do 170, 190, or 220kv. Is there a perk for going with a bigger sized motor? 6396?
KV is the shorthand for “RPM per volt of input”. Basically how fast the motor will rev for a given battery voltage.
Lower KV motors have less RPM, but more torque. Higher KV motors have more RPM, but less torque.
Go to the esk8 calc link up in the banner, and enter in your proposed board’s details, and it will calculate the speed you’ll achieve. Things that affect speed include:
wheel size
KV
battery voltage
gear ratio
Changing any one will change the overall speed you can achieve.
Sweet! thank you for a clear and detailed response. Yea, I’ve been messing with variables in the calculator, but still a bit confused on what all the values mean. (motor poles, efficiency)
Also, would you happen to know the different cons & perks on going bigger with the motor for example 6374 vs 6396.
Bigger motors in general can handle more power, because they can handle more current before the iron of the core begins to saturate, and also because they have more mass to soak up heat.
Pros: more power, assuming you can supply it.
Cons: heavier, more expensive, higher baseline losses (they’re not worth it unless you’re gonna make use of the extra overhead, basically.)
Leave the efficiency at the default 90% and the pole count at 14. You only really need to mess with those if you’ve got weird motors or a really unconventional setup.
The one BIG advantage of the 6396 over the 6374 is that it has a skirt bearing. That means the outer can is supported on both ends, so you won’t have any issues with the can getting bent or loosening on the shaft due to cantilevered forces.
There are 6374s that have a skirt bearing too, like the Hobbyking SK3 and SK8. but the maytechs do not as far as I know, and neither do most of the others (TB, etc.)
Alright this should be a simple one for you guys. On my build I run my batteries directly to Unity.
I used to have a flipsky 6.6 dual that I ran without a power switch and I would connect/disconnect the the batteries when I wanted to turn it on/off.
I have a power switch on the Unity. Would it hurt to leave the batteries connected with the switch off when not using the board so I don’t have to take the batteries out of my enclosure every time?
Just want to make sure there aren’t any hazards involved.
I can’t recommend a size battery without knowing the interior size of the box and the other parts you have packed in there, but the cells will be the same regardless. If you want a good all around cell then either Molicel P42A (21700 type cell) or Samsung 30Q (18650 type cell), if you are trying to squeak out that extra bit of range then Samsung 50E (21700 type cell) or Sanyo NCR18650GA (18650 type cell) but they only crank 10A per cell so you need a really big battery like a 12s8p to have enough kick
Depending on the space in your battery box, you can run 21700 50E batteries in a high p config (let’s say 12s8p) to get a 80A discharge rating.
They are 5000mAh cells with 9.8 (well… 10) amps discharge.
Or if space is limited, the next best option is p42A 4200mAh cells with 35A discharge (way better).
You somehow have to put together all of these and get a bms, charger, antispark (loopkey of switch) and a splitter to go to all your vescs.
You can hit up one of the battery builders on this forum but i’m warning you the price will be steep. The good part is you get the whole package and you just drop it inside your box, connect wires and it’s ready
Why are my wires melting at the bullet connectors on my phase wires? 2nd time now and on the other side this time. Obviously heat, but from what? Bad soldering? Incorrect settings? Please help.
You should cut the shrink wrap off and take a photo of the solder points. (Do not power up the ESC with the shrink wrap removed!) I feel like it’s very likely a cold solder junction could cause that issue. It could also be a dirty or oxidized bullet connector not making a good connection.
