Simulate by hand the force the belt is applying. You will discover what exactly clicks eventually, just don’t break things (yet).
For me one time it was wheel pulley (bolt on) clicking on wheel hub. Too tight.
One time already messed up motors from belts too tight.
And lastly from overtightening some pneumatic wheels with no bearing spacer inside. Bearing was locking up randomly and grinding the shaft.
Take your time and discover
When I freespin the wheel there is a less settle clicking sound but its very faint. When I freespin the wheel with the belt and motor I can hear the clicking sound.
Those “teeth” by where I cut off the extra aluminum. Is this normal? It seems like there were two metal rods joined instead of one solid rod and I don’t know how I feel about it
I’m trying to connect a flipsky nrf1 BT to xmatic app. I keep getting “connecting to VESC”. I already configured it using Unity Tool app. I clicked on PPM and UART and set Baud to 9600. I’m not getting data but when I clicked back on Unity BT I’m getting data. Any help thanks in advance
So I just put the pulley on a different wheel and I still hear the clicking sound. I think I’m back to the motor shaft or the pulley. I’m using the tb pulley with collared screws, but they don’t have setscrews. Should I look into set screws?
