There is also the keyway which is what is holding it in there
yeah but that doesn’t stop it from moving on the axis of the motor shaft, you can still slide it on the motor shaft
Separate question, I just downloaded Vesc tool 2.05 for Mac, is that the correct one?
The motor pulley won’t even budge, not sure what to do
If you have Loctite underneath that motor pulley you need a heat gun and flat screwdriver or pulley gear remover. I recently removed my pulley and I had to use a heat gun.
No loctite, just the keyway
My motor mount wasn’t straight so I adjusted it. Now the pulley are even and the belt is just a little off the wheel pulley
Is there any way to secure these cables down
I’ve tried zip ties but they keep slipping on the trucks and won’t hold it tight. I also don’t have any p clips and don’t feel like buying a bunch of those
but p clips works really work tho, also looks better than zipties
another option would be tunnel riser, but if u don’t want to buy p clips, i don’t think u will want to buy tunnel riser
That’s at least $12 when I only would need one lol
@dnack228 I don’t have any on my esk8s but whenever I have to reorganize a server room during a contract I use adhesive cable tie mounts
Maybe I could use double sided tape or double sided tape with the ziptie
I’m pretty sure you could find pclips or mounts at a dollar store. Atleast the ones here have em
Oh, I didn’t think of that, I’ll look
Dollar store : #1 diy solution to any problem
Is the unity pretty solid? Trying to convince my self not to buy ciscoV’s for my first build.
Should I wait for 60D’s to drop? Gonna be on a street thane build Sidekick probably 6355’s.
#1 need out of esc is for it not to kill me…
You think Cisco gives dicounts for handy’s?
Any input is appreciated!
take @CiscoV’s stock so he will start to sell new stuff
Isn’t he already taking preorder dibs on 2023 stock?
this
(turn it backwards until the plunger pops off, and discard the plunger)
nah man, i was talking about those 2024 stock, 2023 stock are all gone
