The Carver is nice, just a bit slim
Huh…I saw the dark color and thought CF, my bad I guess
But how well does it absorb vibration?
Mostly fibreglass. They say there is basalt in there too, probably on the outer faces.
I assume you’ll be running pneumatics on a flexi deck… vibrations aren’t really gonna be a thing. Diminished response will be though, and the only way to get around that is with a stiffer deck.
What do you mean by diminished response? I don’t go fast at all, maybe 25mph absolute tops (I don’t think I go above 21mph on most rides) so no worries about speed wobbles really, I just need it to turn decently
But I suppose this in 12 ply? The +5° tips and shorter base should give better turning right? (I run yellow shock blocks and turning still sucks)
thanks I’ll pick some up at the hobby shop next time I’m there…
old sk00l RC body mount pins…
you lose steering response as a flexi board absorbs some of your lean energy
Just reaction time or do you loose radius too?
you have to force more energy into a flexy board to get it to turn equally to a stiff board…
Ah damnit
no free lunches
BTW the kaly boards can be bouncy… but they are torsionally stiff… so they carve quite well…
I’ve got a stiff kaly and while not what I would call her a flexi-board she is supple enough to absorb road shock but stiff enough to carve well
Hmm, I wonder why it has good torsion resistance…I suspect the segmented enclosure is what does it?
negative ghost rider…
the ABS enclosure adds little rigidity… It’s the construction and the width
Weave direction in the layup
Does the Trampa stuff inherit those properties?
Trampa’s seem to twist a lot more. I would assume that the wings on the kaly help with the torsional aspect too.
YUP
Ugh that’s upsetting…I hate the look of the wings and ends. But no accounting for bad taste I suppose
I like to ride flexi boards sometimes…
and sometimes I like a stiff ride…
I haven’t ridden a million boards like some here have, the absolute stiffest board I’ve ridden is my Century 40… that’s like riding an iron girder… but so-so precise steering input to response…
BTW
@ZachTetra
I just went and jumped on the middle of the kaly…
and I “think” i heard the first discernable beginnings of a crack on the ABS enclosure…
