Has anyone tried dickyho’s normal mounts with pneumatics?
Axle to motor distance is adjustable between 77~81mm
I would want to fit 15~16t to 60t belt drive and 1 idler.
I have calculated that i would roughly need 365mm belts (maybe 370 with the idler?) but i’m hoping to get some advice from someone who did it already before me before throwing money into the issue.
Help?
anecdotal evidence at best, when I bought a Kaly i also bought a second Hoyt receiver, and the Vx1 that came with the board has operated flawlessly connection-wise for many months and miles, on a Unity… I’m not planning on knock on wood opening the enclosure up and swapping to a hoyt till I need to…
only thing that is borked on the VX1 is the voltage LEDs my board is depleted when two LEDs flash down to one lit…
BKB doesn’t have kegel adapter anymore.
dickyho, Fatboy and EboardSolutionsboth are either 15 or 16mm, all require longer axle
haggy would require 6001 bearing to fit on 8mm axle, which can be done, but i want something easier
I haven’t seen moon’s pulley, unless someone sells it
It should be possible to use caliber etruck if I want to use 15mm pulley?
