I’ll try drilling a hole in the screw with a… Drill
Will buy wera!!!
Will buy wera!!!
No, those drills cut while turning counterclockwise. They aren’t regular drills, you have to turn them backwards
Option B is to cut a slit in the bolt and remove it with a flatheat.
Yeah thanks! Tried with a powered drill, but no success…
No easy way to get them out?
Idc if they survive… Just want my motor
That’s the way I want to go - how do I cut the slit?
@xsynatic
dremel
And if you don’t have a Dremel?
buy
Do they have blades small enough and strong enough to cut through bolts?
research
Love the one word answers
Dremel
yeah mine stripped too those are shite
i drilled it out and then used pliers to take out the threaded part
you can edit your posts
and deleted ones?
You don’t need to delete comments if you edit the other ones in the first place, before posting another.
Hiii would changing the shunt resistors to a higher ohm make the current measurement more accurate?
Does this apply to the OG Focbox? I’m running a 10s, 37.5 battery max, and FOC mode. Also is the default mode FOC when you setup a motor through the vesc tool?
No, only the VESC 4.12 or any other VESC derivative with the same MOSFETs. The FOCBOX 1.3, 1.6, 1.7 all have DirectFETs and are not the same. (But do use 410,411,412 firmware versions)
