If you don’t adjust the ERPM limits you can still brake.
Question for you fine fellas: I have a spintend ubox and the remote broke. What remote can I get that’ll pair with the integrated receiver that came with the ESC? Besides the $60 one on the spintend site.
Also a question: Are any of you using their batteries for charging of other devices on the go (like a powerbank)? As I think about removable battery packs in my project I also thought about other use cases of the removable batteries. First thing would be to use them to charge a phone or even better: a laptop.
I already searched a bit for DC to usb-c circuits but most of them only have usb type A (5V 2A) and some usb-c ones that support Power delivery (up to lets say 60 watts for laptop charging) are limited to 4 to 6s batteries and often include a bms which I would not need because of the one i put into the pack itself
Anyone got an idea what to search for? Are step-down modules without “PD 2.0” or 3.0 specification working like as a power delivery over usb-c?? I would guess it needs to offer some sort of communication between the charger and the device (about charging voltage and such)
so far I only found things like this: Netzteilmodul 6 - 40V -> 5V / 3A mit 2x USB | Kaufland.de
or this: https://www.gmelectronic.com/module-usb-c-power-supply-zy12pdn#product-detail
but the last one isnt clear about the direction the power goes (i mean there are modules that turn power delivery over the usb-c port into normal DC output for powering other non-usb devices and its unclear if its that or the way/direction I look for)
to be more clear: the ones I mostly find are “trigger modules” for power delivery power sources but I want find a module that goes the other way and steps down from 10S votage about/above 36V to the 20V for the PD (maybe I need two modules? one for the step down one for the PD communication between usbc and charging device?)
@jack.luis is he has a USB C thing on his
I think the route was buck converter, then the USBC board
I always hate answering a question with “but why” and especially on a DIY forum.
But why do you need to use only the builtin receiver? I am curious.
Also fuck you with the condensation
Oh my goddd haha I didn’t even realize he typoed I would have posted this
lol, it cracked me up - I couldn’t resist
Any real difference between 18:44 and 15:36? It’s the same speed ratio so it’s just a matter of is there more stress on the belt from more tension (15:36) or from a higher surface speed (18:44)
18:44 would be my preference, more tooth engagement on the motor pulley and the belt can bend in a larger radius which might lead to a longer belt life. No significant difference though.
Good, I got 15/44T now and the 18T is definitely cheaper than the 36T
Possibly lower ground clearance with the 44t, I remember that being an issue when I looked at 62t and 70t sprockets. 70t was too close to the ground for my liking.
It’s on 110s with 12mm belts and 184mm hangers (no spacers) so I’m not too worried
Oh also Chubby or Magnum for BN hangers?
None of the higher-powered USB supplies I’ve seen will natively handle more than ~30v input, so I think you’ll need a DC-DC converter to bring the battery voltage down at least that low. Luckily there are some pretty small and power-dense converters available so you won’t be losing all that much space.
The two main types of high output USB power supply that I saw while working on my ebike are the round panel-mount ones for cars/ATVs/motorcycles/etc, and the “PDS100” type little modules available on Aliexpress and the like. Both need a minimum of 12v, and a maximum of ~24-30v, too low to run directly from a 10 or 12s battery.
Yeah, you need two modules, but the one for PD communication also does a fair bit of the step-up/down, because PD is a multi-voltage protocol that covers the whole range between 3.3 and 21V in 20mv steps (for PPS mode in PD3.0), and up to 48V for the upcoming 240-watt PD standard that was announced a while back. You can’t just feed 20v into a PD transceiver and have it poop out the other side, the protocol just doesn’t work like that.
I don’t need to only use the built-in receiver. Just thought I, if i can find a remote that’ll pair with it, might as well utilize it.
Thanks a lot! With one of these
I imagine I can just hook up a step down module for 48V to ~25V to it and it should work?
I would also guess the efficiency for the whole process differs strong with larger voltage gaps?
Some charts I found show a weird efficiency graph being at best 90% (shouldnt these come with heat sinks when they burn at least 10w while running at 100w output power?
Correct.
Yes, and also the efficiency depends strongly on the exact dc-dc converter used. Some can be better than 97% efficient under certain conditions.
90% efficiency is still very good considering the wide possible voltage range. Yes, for high power operation they should at least have a chunk of aluminum for thermal mass.
I am using the calculator from b264 and I am unshure about the average powerconsumption. I cannot find any information about that number for these 6inch hub motors exept for one post where someone answered that he thought his 6 inch motors were bad with 25wh/km
(do i need the working system for that and run some logs or something? and need to setup the wheel diameter i guess for speed/range)
also the calculator is meant for each drive? I mean should I handle a “dual system” (motor, esc, battery each) as each a system or should I calculate that differently?
