In the video you can see that he’s drawing 30A before the notification pops up. So I think the voltage sag is expected; he should probably limit his battery current to 20A per side.
Strange that his consumption is so high on the bench though, I wonder if something is causing drag
Maybe running as root / adding your user to the correct permission groups would allow it to?
Also, can’t chromebooks run android apps? Maybe the mobile vesc tool app works
the mobile version works fine, but the mobile version ONLY lets you connect over BT and not USB/TCP or anything else, plus I just hate the mobile UI and prefer desktop VT.
I was so pleasantly surprised to find the full apk runs the desktop UI on my chromebook, but still isn’t able to access USB
Add: I have also never, even after 3.01 ever been able to make metr work as a BT for the VT app
I’ve tried it with a force-closed metr app and I still can’t get it to connect, what are you doing differently?
For me TCP works fine and is the only way I can connect currently, have you been able to successfully upload new FW over TCP through the metr? FW is the only limitation I’ve found.
that was an entirely different metr device, I did that on the metr.pro, I’m currently using a metr.unity with the pins replaced with a UART cable (4 connections)
sigh… I have a test ride to get to today, if another unrelated issue turns out to be a HW connection issue I’ll have to open up the enclosure anyway, might as well get at the USB while I’m in there.
I truly yearn for the day when I can do all config and settings functions wirelessly and without hacky workarounds like using my phone for TCP to BT ad-hoc connecting
