Yep you are correct, I’ve already screwed my chances of being able to return the battery.
I’m hoping I can sell it for something to make it less of a hit but who knows how long that will take. I haven’t used it since my initial issues and from all of these responses I have pulled it off the board and won’t be attempting to use it there so that I don’t completely destroy it.
The only thing that really saved my ass is the fact that I have this pre built dual hub motor board with the bad BMS that I was given and I’m going to part it out to help with the cost of a new battery.
I would not use them there. Unless you’re not concerned about having a short lifetime. But then that just eliminates the benefits of using that cell in the first place.
I’m running 5.1 FW on my fuel Trampa Vesc 6 mk3’s
With Trampa 160kv motors . I’ve had a couple experiences where when I’ve been riding at about 20 plus mph and under load I’ve felt a sudden dip in the power for 1-2 secs causing me to wobble a bit (heart in the mouth feeling) not nice . It’s not a wand signal issue and I’ve not suffered signal drop ever ,so I was wondering if it might be something to do with the temp sensor issue you guys are referring to. If so will the 5.02 FW sort it or can I do something already to help fix it ?
If you have a wand you have a nrf module. Log your rides and check from where this drop outs are coming. If it’s connected with the temp readings you will see that in the log files.
This is not a troubleshooting thread so maybe start your own thread or ask in the noob questions thread.
The first thing to do is figure out if you got a fault code when this happened. Any fault for any reason can cause a single side cutout, and feel like what you said. If not a fault then telemetry on the motor temp or just disabling motor temperature sensor by depinning it, or unpluging hall and temp sesnsors and going sensorless will help debug if that’s your issue.
FWIW VX1 is so much better feeling than the nano-x or nano.
Hoyt Puck and the mini are both considered far more reliable than vx1, or nano variants.
consider doing the receiver change out and upgrading. if you’re tight on funds the mini is affordable. (mini mods can make it thumb wheel if you prefer that. )
Ok I’m looking at purchasing a 10S3P 30Q brick from a member on the forum that has a max of 60A continuous discharge, is that a pack that’s suitable for a dual 6354 belt drive setup with a Dual 4.2 FSESC?
I’m still trying to learn everything about the max discharge amperage needed but with my mistakes from the last pack I want to get a second opinion before buying it.
Find out what cells they are and look at photos of other packs they’ve made. If it’s a respected member and those are 30Q cells, then yes that will work.
I’d set those ESCs to max of 20A - 25A per side, not the 99A default. Better to not run the battery at its max rate.
With a dual VESC the battery current max in the vesc tool is per VESC and not for both correct? So I would set it to 25A and write that config to each VESC.
Also is 25A per vesc powerful enough so that I can hit my top speed? I’m not super concerned about extreme acceleration but I want decent acceleration as well, which is the battery current max what will determine the acceleration, top speed, or both?
