Easiest solution is just to not connect the sensors, and not use the sensors.
It’s weird, it was working before
I replaced it with another motor but I’d still like to have that one functional
then the burning question…
why don’t you figure out whats wrong with it, and fixerate it?
That’s the plan
forward for science my brother…
remember when you said it was working before?
and you know who is the only intervening person…
i’m not saying anything bad about you… but we’ve all fukked shit up… retrace your steps…
I wish you the best,
Well yeah haha. It did go through an ESC fire at one point. I’m just going to start by cutting the sensor cable higher up towards the motor and replacing the wires up to that point
your science is approved
Apex RC Products 70mm Silicone Brushless Motor Sensor Wire Cable - 3 Pack #1040 https://www.amazon.com/dp/B071VBBKF6/ref=cm_sw_r_cp_api_i_iswdFbR362KGW
Are these (above link) the same as these =
Can you swap the motor/esc wires around to reverse the rotation of the motor? or does that screw up the detected values? using sensored foc. should i just reverse the motor direction in the vesc tool?
Yes, you can manually swap or simply reverse in Vesc Tool.
would that not mess with the readings from the hall sensors?
No not really. You will have to redo detection though.
I recommend swapping 2 phase wires instead of doing it via software. I’ve had the settings on my board randomly revert to default before and it would have been nice to not have a motor spinning the wrong direction.
What was your question?
Best Capacity cell for a 30A esc in 10s2p config?
No
SPIM08HP
Ah I see the question hidden in there now.
@kadeanderson one is just an extender, one is an adapter that changes the connector.
Seriously though, just use P42A
