I do suppose my wording of “breaking something as a result of not having a fuse” could be confusing.
Hybrid ≠ FOC. They don’t work the same. Sensors turns off when adding current to the motors in BLDC hybrid. It only works for a short start up, but will break the sensors eventually.
Edit: FOC should be used to see if you had the same noise since sometimes that noise is usually from BLDC. It can help to see if it’s the bldc mode or the motors itself if you hear the same sound in FOC.
While this is technically true, which is the best kind of true, any fuse in there will help you. If you put a 12V fuse in there, it will be fine. Just make sure the current rating on it is about 110% to 200% of the maximum charge current you want to use.
That actually sounds a little big. 7.5A would be perfect IMHO
I disagree. While it’s not guaranteed to happen it’s just not worth the risk of the short-circuit current arcing across the gap and blowing up the fuse, possibly starting a fire. The correct voltage fuses are always available. The right fuse will just sit there and open up if there’s a short-circuit.
For those in the USA, I have 58V fuses on the cheap
Charge port fuses shipped to USA $2 each, limited supply. No tracking. 7.5A 58V or 10A 58V out of stock [20200623_211105] Sorry, this offer is only open to USA at this time, as I ship them with a stamp. These are available from Mouser though… for a much higher shipping cost, unless you’re combining it with another purchase. 7.5A for up to 5A charging Please PM if interested
mouser charges like $0.56 plus $7.99 shipping for just a single one
Just solder it into your charge port circuit and silicone/epoxy/hot glue it inside the enclosure.
Do you know where I get get one for 50.4V for UK for 4A? Cant find one anywhere for the correct voltage
It’s in that link above. Just change .com
to .co.uk
Cheers Brian !
Anyone had experiences with hobbyking? How long do they take to send an order?
i sometime buy from them, but i can’t really say much about their shipping since i live like 10mins away from their international warehouse in Hong Kong
Their shipping hasn’t been bad for me in the USA but I haven’t ordered from them for a few years.
Well, seems like an item in the order went out of stock after i paid. Spoke to support to cancel that item and hopefully it ships today
Dude, what a coincidence, I live like 10 minutes from their US warehouse
Quite good for my recent order.
Ordered on 13th.
Shipped on the 15th
arrived on the 23rd.
Used the cheapest shipping option that was not tracked.
Hm… what does “available on backorder” mean from aps? I can clearly see what is in stock and what is out of stock, but this? Do they just dropship straight off the factory whe orders come through? If so, am i not just better off ordering from the source? I think it’s saite motors.
You can “preorder” as it’s not in stock. Once it’s in stock you get your item.
Means probably wait to buy it
Ah, the classic money trap. “Will it be one week? Will it be july? Put £250 here and find out!”
There are very very few vendors, even trusted ones, I will preorder from. And definitely only if I ask, not if they ask.
