If you care at all about safety, please buy name brand fuses
An interesting video from Louis Rossmann, testing inexpensive China fuses available on Amazon…it did not go well: https://youtu.be/B90_SNNbcoU?si=ecLqlNAYLc0p6wFx
One brand might have properly behaving fuses but the others are downright dangerous.
Please buy name brand fuses (Littelfuse, Eaton, etc.), those which have a datasheet. No datasheet? Forget it, don’t buy them.
Here’s a datasheet for Littelfuse 32V blade fuses: https://m.littelfuse.com/~/media/automotive/datasheets/fuses/passenger-car-and-commercial-vehicle/blade-fuses/littelfuse_atof_datasheet.pdf
These are too low in voltage for esk8 use but match the ratings for the fuses in the video.
Things to note….
  • Use the time/current curves (“I2T” curves) to see how long it will take the fuse to blow at different current levels.
  • No fuse blows at its current rating (at room temp) for a verrrrrrry long time.
  • Name brand fuses will blow much sooner than the junk in the video.
  • Fuses used in higher ambient temps might need their current rating lowered. The datasheet will have a table for that.
  • Using a fuse with a voltage rating that’s lower than the voltage of your pack could result in the fuse arcing over when it blows. This can cause it to burst and start a fire.
I think the non branded ones are technically “fuse shaped novelties” that way amazon isn’t liable for the harm they cause. Whatever happened to consumer protections?
Forgot about linking this:
I found some pretty high voltage fuses also and linked them down the thread but here is easy mode 15a 80v automotive type:
https://www.digikey.com/en/products/detail/nte-electronics-inc/74-AFP15A/15668280
