I get really scared about riding with bindings unless I have to, you can snap an angle if you fall at speed while strapped to the board, I should get half bindings at some point
The one time i almost snapped my ankle was with the freebord bindings… one foot came off the other stayed… really can’t recommend them. Either completely locked in or not locked in at all… middle ground seem to be asking for trouble. DERAIL JAIL ME!
I think it’s because freeboard has the bindings outside, I like the onewheel style more
full bindings no. you can break ribs, wrists and arms but ankles are the least at risk
I do like them for off road for sure though
I have them mounted on a Trampa deck right now but have to finish the build to get them out on the road. Standing on the deck, they sure do turn like crazy however the Trampa deck has 35-degree tips so I’m not sure yet whether I may have to dewedge.
I understand from Ethan that he’s working on the 45-degree baseplate.
I am concerned with how low the kingpin is for off-road. I’m not sure I’d want to ride off-road with these on 8" tires. The build I have them on will have 9s. Although maybe it just looks a lot lower than it it really is. I measured the difference between the bottom of the Apex Air pin and the Newbees and it’s about 15mm lower or so.
Yeah, considering the axle base on pivot truck design…the kinpin is the issue that cannot aviod, otherwise if we follow the standard RKP design, the wheel base is obviously too short. But those kinpin is easy and cheap to replace, been running my truck for couple months, kinpin just had some minors damage.
What do you guys think about a version with a shorter hanger for road use?
And add a bit of rake while we’re at it ![]()
I don’t think the rake is necessary…since you can not switch the hanger around to get rake switchable. ![]()
Just a note for anyone else thinking of putting Apex Jump Drives on RTKP, the Air hangars (and hence their clamps) are filleted while the Newbee hangars are chamfered. Frig me. The standardization discussion we had around the Matrix 3 profile comes to mind about right now…
Damn, this is what I had in mind haha.
I’ll have to modify the clamps. It’s just a pain and yet another missed opportunity for standardization.
This is why we can’t have nice things ![]()
Chamfers are much cheaper than those rounded edges on the Airs. Kind of makes sense
#firstworldproblems
Well Matrix III are also a lower-priced offering and have chamfers on all edges, although oddly two large radii and two small. It would just be nice to have some standardization. Between the three hangars, they are tantalizingly close but just different enough to prevent interoperability.
And yeah sure it’s a first-world problem. Most of the problems we have in esk8 are.
Rounded edge won’t increase the cost too much, just different design language ")
the hangers are also forged and welded not cnc’d from a solid block.
if the gap is an issue fill it with sugru or silicone
