There is a new esc being sold by Flipsky, what do you guys think of it?
I’ve been looking into buying a new single motor esc for a while since my last 4.20 broke, at first look this looks like a good option that isn’t very expensive?
Flipsky has always been hit or miss for me. My first board went through 3 in a year and a half. I think they are only good if you need something cheap and only plan on using ½-⅔ it’s power rating
Im about to drop a review on the Flipsky Smart 4.2 and im very impressed with it. I dont have any experience with flipsky ESC’s before this but at least this one is very good
I just saw this and am thinking of getting one to help a friend with an ESC swap from a hobbywing. I wonder why the dual 6.7 costs $156 whereas the dual 4.20 is $178
I think this is the main issue with Flipsky, they for no reason put ratings that aren’t really suitable.
Their rating are correct, only with a drop through heatsink. Most people don’t use one, so they blow. Not sure why they put 13S ratings on their 60V products either.
If you knock down their stats 3/4ths, they’re still good value, and reliable.
I think this may be the reason why my last one broke, I might’ve pushed it a little too hard, I’ll make sure to be carefully and look into some heatsinks this time if I get this option
2 reasons I can think of: their new products are often introduced at very low prices to get exposure through click bait videos and/or “buy” a reputation for great value. The less cynical answer is the products based on mature hardware have run into serious supply issues so they redesign around new suppliers and availability
Yall probably wait to see Lee’s review before purchasing but I am optimistic about it too
Flipsky has had some solid reviews in the past, people with thousands of miles and no issues, but you can’t ignore the many people that have had failures. I’ve heard the 6.6 versions are quite solid, but this new one I think will hold up much closer to their actual ratings that they put on the site versus the old ones.
How hard do you think you could run that dual flipsky vesc? Maybe like 70a each side?
Edit: Wait, does flipsky mean 140a for both sides? I guess that would make sense considering their single version is 70a rated
For the record, the two Flipksy Mini FSESC 4.20 in the Green One have had ZERO ISSUES and I ride it all the time. But I also run them at 10S and 21.5A battery max per ESC.
This is always the issue with being sent stuff to review and it’s something I have touched upon in the video. I can’t answer that question in all honesty.
