Need reliable VESC - MakerX M100 failed/fried during motor detection
Hey everyone, I haven’t been on the forum in awhile but wanted to make a post to see everyone thoughts. I am troubleshooting an issue with my board frying a VESC and also in search of a suitable replacement hopefully within ~2 weeks.
My current setup:
  • TorqueBoard 6380 (single drive)
  • 12s battery
  • Old VESC: MakerX Mini FOC Plus (had for 2.5 years and 1000+ miles and recently stopped working)
  • Settings: 30A battery max / 50A motor max
Recently I ordered a new MakerX Go-FOC M100, on the 1st motor detection VESC tool gave “'Flux linkage detection failed”. On the 2nd attempt I got “Detection failed - VESC disconnected during detection”. After that my BMS short protection would trip when attempting to power on. And tested multimeter I had a short between + and - battery leads.
So now i’m stuck, I haven’t contacted MakerX support yet but will. I ordered it 5 months ago and didn’t get around to testing till last week so hopefully it isn’t too late.
What I need help with:
  1. What might have caused the M100 to be fried? Is my motor the problem, or something else on my board? I just want to make sure I do not fry another VESC.
  2. Where can I buy a VESC with 1-2 week shipping that is reliable?
  • I saw amazon only has flipsky options (would the 75100 and 75200 be good for my use case)
    -Would it be better to buy from someone on the forum or elsewhere online and just wait. If so, what VESC would everyone here recomend for my setup. I do not need more power than I had before, I am mainly focused on reliability. (Also open to offers for VESCs that people are selling)
Thank you for reading. Hopefully you guys can help me out!!
Are your motors ok?
Any way to double check that
How can you check if the motor is good? During the 1st motor detection it did spin up. I have it for ~2 years and it’s got a tiny bit of surface rust.
@b264 help…
Would highly suggest checking the motor. This sounds like the motor died and has now taken both escs.
I did the hand test, and the motor did great. No play or grinding. Any 2 phase wire shorted was “some” braking. And all 3 was much stronger and smooth braking. I will do the other test with drill & multimeter later today.
I cannot speak highly enough of my SKP ESC’s - they’ve been plug and play for the past two years, zero issues running massive bioboard motors on an 18s7p setup. @Skyart Not sure about current stock or delivery times but checkout https://skyartpower.com/products/skp-solo-esc or try messaging the man himself - @Skyart
I preformed the motor test with drill. I got very consistent AC voltage between all 3 phase wires.
I also just got my motor to spin up using a 2nd VESC, so motor is not bad.
Any ideas on why my MakerX board would be fried and have a + and - short.
I also have another question I posted in the beginner questions thread
https://forum.esk8.news/t/beginner-question-thread-2023-edition/66072/7486?u=connue990
