Mr Board : Landyachtz Evo Falcon 40" | TorqueBoards Direct Drive | 12s4p | Dual Flipsky 6.6 Plus
This will serve as my secondary commute vehicle. I wanted something fun and relatively low-maintenance to take me to work and class.
Full parts list:
TorqueBoards Direct Drive + 110mm Wheels Ordered
TorqueBoards ESC Sensor Wires x2 Ordered
TorqueBoards 5.5mm to 5.5mm Extension x2 Ordered
Psychotiller 12s4p
Psychotiller Evo enclosure
Flipsky Dual FSESC 6.6 Plus Ordered
Flipsky Bluetooth Module V6 Ordered
Flipsky VX1 Ordered
Flipsky 5.5mm Special Banana Connectors Ordered
XT90 Connectors Ordered
This is my first build so I know I fucked something up. Any suggestions will be appreciated.
Also, I want to move the TB DD onto a Trampa deck at some point, but I have no idea how I would go about doing that. Would rey8801’s angled baseplate be the solution?
I mean there are always little things that you need to get before you hit the road, but this is gonna be a beast of a first build!
Which Trampa drive set are you referring to?
Ideally, I would just plop the TB direct drives onto a Carver or HS11 deck. Pretty sure directly mounting them would cause clearance issues, so I thought that the adjustable baseplate might be able to solve that problem.
Plenty of evo builds to choose from my friend.
Mine:
@Dareno
Evolution. Landyachtz Evo 39 | Torqueboards 218's | Dual 6374 SK3's 192kv | 97 TB wheels | 12s | Focboxes
And there are others, the two best for a start :joy::joy::joy::call_me_hand:
