Hey Team – This is a rendition of my build in another space, without all the boring crap.
But I will say again - I probably should have named this build Apprentice Evo, after getting so much inspiration and information from @Deckoz Brad and his Master Evo.
Purchased / Received:
Deck: Landyachtz Evo 39” (concrete lines skate store)
Enclosure: @eboosted custom evo standard enclosure
Wheels: BOA 100mm Red
• Bronson G3 Bearings
Trucks : Caliber II 44° Red
• torque boards hanger on order
• Sector 9 Wedge Riser pads Black
• Lux Wedge Riser pads Red (didn’t use)
Gearing :
Build Kit Boards @BuildKitBoards
• 15T Motor (didn’t use – ended up going with 16T TB pulley)
• Kegel modular pulley set 36T
• HTD 265 - 15mm belts
Extras:
Customer Evo X braces from Matt @akhlut.
Bestech D140 Charge Only BMS (BKB)
Motor : 2x Torqueboards 6374 motors
Motor mount : Torqueboards V5 Fixed Dual Motor Mount Set
These didn’t work – Dexter happily replaced them with red mounts.
ESC : FOCBOX Unity – I finally got one thanks to my boy @skunk – That’s a bloody epic story no-one needs to read.
Battery : 12s5p – Built not bought. Board hasn’t exploded yet, so something went right.
Remote / Received: Entertion Nano-X – on to my second one. Waiting for Andrew to give me something better.
BATTERY:
Bought Samsung 30Qs and tested them all.
Put them in the configuration for a 12s5p, and once I was happy with everything, started spot welding.
I haven’t been able to find a big sheet of fish paper in Australia, like I see people using to insulating the batteries, but there is sticky fish paper sheets stuck in between the batteries length ways.
My friend Roger keeps saying Insulate, Insulate, Insulate.
My pack is wrapped in so much kapton tape it isn’t funny.
Braided Copper wire is used between 7 – 12p groups to hold it all together.
I didn’t go pretty with the balance wires, but it does the job.
MOUNTS:
As soon as I roughly put everything together to see how it would go, I knew I would need to use a riser. I had the 1/4-1/2 inch wedge riser. I had to get longer hardware and some .5” risers to work with the curves of the EVO.
MOUNTING ENCLOSURE:
Pro Tip: Measure and align 20 times before drilling. And drill one hole at a time making sure everything lines up.
I used stainless steel M5 wood inserts which cost an arm and a leg, however are great.
In my case I got the 4 bolts (2 at each end) done perfectly, however I did the last six middle bolts in one go and the enclosure somehow ended up slightly to one side. There is still a gap between the enclosure and the edge of the board, but when you’re going for perfection, it being off center is a bit of a let down. I don’t even notice it now at all.
BUSHINGS:
I sent the legend Brad @RipTideSports from Riptide a PM with my build info and what I wanted to do, and he recommended some bushings for me to try out. I ordered through the site and have them all ready to go / play around with different combinations.
I actually want to go the pink all round to hopefully be able to turn slightly better. I made this board for speed and it does exactly that. So I’m in no rush.
Final Product:
Issues along the way:
My TB 6374 retainer rings both went at one point or another.
Fortunately, I had received extras from Dexter in anticipation so it was an easy fix (especially because my friend did it for me)
My original TB Motor clamps just slipped. Every ride I would have to readjust and tighten, and move, etc. etc. etc. It was
So what did I do, I laced those bad boys up with red locktite. And guess what, it didn’t help at all. So I ended up having to grind the bloody things off the truck.
I now have the TB V6 mount, and it’s bloody beautiful. Hasn’t moved one.
Thanks again to Dexter.
The Guts
The enclosure is great at keeping out dust. I opened it up the other day to put a METR in the board and it looked great in there. I was riding this board 30km a day in summer so it has done some distance.
Everything is Velcroed in there, there is so much foam for insulation and to stop vibration. And then I have just taped things down for the hell of it.
Special thanks to all my boys -
Any questions let me know.
Cheers
Moone
