I just want to inform that you could buy them with sensors at Ali…Agree with you about HFI, cause I have a board running that way with great results…But my everyday board have TB 6380s and I fuckn love them…
link?
Yeah I do love the TB6380 motors
How many motor amps u successfully done with HFI and how big a motor?
I haven’t tried it and waiting for motors to show but vedder said it can lose sync from too many amps.
@Santino
It is my wife mountainboard…so amps are 50 per motor, 2 destroyed Maytech 130kv sensorless…And she is very happy with the change…I ride it and it feels smooth, really a great upgrade…but did not push to many amps my self
The most so far is
on a TB6380. And this is single drive, so it’s driven closer to the maximum at most times unlike a dual.
Has anyone here had issues with flipsky 6384s temp sensors?
Mine don’t seem to work.
not getting any temp readings on metr app
Wiring issues may!? Any ideas!?
Thank you guys
Do you happen to have the I, R, and L values from motor detection for those? Just curious is all. Not super important
@b264 I don’t think I can get that info with the app witch is All I have to Setup my board.
Can I find it there?
Try to measure the termistor pin to ground and to 5v pin. The thermistor should be wired between ground and it’s pin
You should measure a resistance of around 10 k between it’s pin and ground, and open circuit between it’s pin and 5 V. If it’s the inverse it won’t work with VESC
Aw man. Just Got done working on the boards for the day “enclosure bolted back on and everything shrink wrapped”
But I will definitely give it a go next time I crack it open
Thank you for the help
Motor Current Max 120A
Motor Current Min -120A
Battery Current Max 120A
Battery Current Min -150A
Absolute Max Current 200A
Unity and dual 192kV SK3 6374s.
[edit] I’ve since adjusted Battery Current Min -45A to not ruin my battery, but ran HFI successfully with those settings before. [/edit]
There are several apps. I usually use the desktop application. If you mean Android, I am not familiar with that one.
Yes. I meant android app
Rock the unity app with an old android phone
iPhone user over here
Is that total for both motors or each motor? I’m guessing total. What’s the max it’s actually hit in logging?
Each actually. I’ll have to review, but get over 80A per motor a lot.
Well that looks like a “feet left board” fault
I hope you’re okay
Bindings prolly saved the day ![]()
