Why not bolt the VESC to the rear of the board and keep the phase leads short and just make the battery lead 1.5m? Your board would still be super light and you don’t need to worry about phase lead or sensor wire issues.
Have you considered the flipsky dual 6.6 200a? This has been my preferred VESC. It’s rock solid.
Haha maybe the one you got was rock solid… there are plenty of people out there that weren’t so lucky. I’d rather push than run a board with a flipsky product on it.
Just make sure you do the detection with the long leads, and preferably with them stretched in the same way they are when you ride so the inductance is measured correctly
I’m more worried about voltage spikes going back to the ESC than stator position calculations. At least the phase wires are 10AWG so less internal resistance than 12AWG.
I wouldn’t worry about, if it was on the battery side, then it can be a problem, but unless you are running 10’s of meters, the inductance of the longer wire is around and order of magnitude smaller than the motor itself
Due to the windings, and the length of wire in there? I thought tightly wound wires reduces the inductance thereof, as opposed to a long piece that’s not wound?
