Figured it out, friggen Hoyt Puck was in mode 1, applying expo to the PPM output.
FWIW my setup is a Unity on an MTB with Trampa trucks and 165mm pneumatics, being driven through dual e-toxx 1:4 Mini GDs by Turnigy SK3 6374 192kV motors at 8S with two Turnigy 4S 6Ah 65c Graphene LiPos wired in series.
Unfortunately for me, the Unity’s system limit is 120A. I’m going to bump up my Motor Current Max Brake though, -60A doesn’t even come close to locking up my wheels.
This is an example of a question I’ve had for a while. Your detection shows your motors can only take 54A. Why do you have the esc motor amps set to 80? Aren’t you just wasting energy?
V1 started with these same LiPos, then I built the Headway packs which couldn’t supply the current I needed, and now back to the LiPos until I have saved enough money to build a replacement Li-Ion battery pack.
If I wanted to try LiFePO4 again, I’d need to go with the Headway 38120HP cells. All things considered though, for long range capability and my safety requirements, going Li-Ion with cell level fusing is the only way.
Ive been teetering back and forth between going LiIon, LiPo, or A123 LiFePo4 but haven’t found anything that suggests that anything other than LiPo or 26650’s are the current ‘expected MTB’ cells.
So I had a buyer for my LiFePO4 pack, and thought I’d do a test run now that I have metr Pro, just to be sure I’m not selling shit.
It performed absolutely fine, and while it’s not the super high output pack I thought and had some voltage sag during operation, it didn’t feel significant enough while riding to put me off such that I’ll sell it.
Plus, now I have triple the range than my LiPo setup, no fire hazard, and I can just build two more 5S LiFePO4 packs to go to 48.9V and 65.2V!
