This build will probably take a long time.
The reason for that is that I want to take my time with it.
This will also serve as a way for me to have a spot to look back on, and at the same time, hopefully, some more experienced people will be looking over my shoulder to correct my mistakes.
Nacho
January 28, 2024, 10:39pm
2
These are good places to ask questions as well
[CLOSED]
The battery builders club has been split off for a new start
Please continue in here:
Batteries are dangerous if not treated right. Nobody want to have a fire at home or lose a board due to a wrong battery design.
This thread should be a summary of clean safe battery packs as well as a place where you can come and ask questions all about how best to build your own pack. Feel free to upload pictures in progress and ask our opinion about the layout, weld…
I see the same question being asked by many newcomers here so I would like to shed some BASIC info on batteries used in esk8, notation, configuration, ratings, etc.
Battery Notation
Common battery notation you keep seeing or will see is a (XX)s(YY)p battery with (ZZ) cells:
XX is the number of cells you have in series ( s ) type connection.
YY is the number of cells you have in parallel ( p ) type connection.
ZZ is the actual battery cell type used. At the time this article was writte…
Thank you for that. The only thing that I’m having trouble right now is finding the right nickel strips specifications.
That will be an awesome battery. What about pre-cut options or a nickel-copper sandwich?
