Metr Pro Updates
yeeah
Is shipping to Australia finally available?
We are looking into better shipping options right now. Please wait, me and @hexakopter will update
Today me and @mackann will test a new feature, stay tuned for the demo :grimacing: Coming in about 3 hours :grimacing:
When I’m looking back over my records, I can’t easily tell which of my boards the record relates to. It’s there a way to label the records with the name of the Metr Pro that was used?
Are we nearly there yet?
Connect to the correct metr module, go into records and toggle off “All records”. It then only shows the records of the module you’ve selected.
Well, I’ll be damned. Thanks @xsynatic !
It would still be cool to label the records though.
Second this.
A small tag to indicate which module the record corresponds to.
Screenshot_20210503-141548
Screenshot_20210503-141441
423c375c2e12c1a708ecc1694e472ff1 (1)
Is this some sort of live update?
Real question is when this new LTE version will be available and is this CAN?
Too cool! Any possibility the app itself connected to a metr pro or metr can could do this in the future?
@rpasichnyk cheated
Wow fancy packaging between the board and the BMS :sweat_smile:. And it worked :nerd_face: :open_mouth:.
This is awesome :+1:
Nice work
Yes it was LIVE multiplayer location sharing :slight_smile:
Yes Metr LTE will connect over CAN, and hopefully will be available this summer!
Yes, technical possibility is there, just needs time (which is very little at the moment)
sounds like you guys now have GPS + integration with VESC + Davega as monitor
  • if you really add SIM card to it and add tracking on on the map into APP you will have complete tracker = I guess thats what you are going for.
But if you were to add or use gyro from Davega or VESC then you could also act as very effective Anti-Theft device! (Can activate ALARM mode from phone APP, send push notification to the phone if gyro movement detected, and even activate full motor breaking- would be very effective on AWD bicycles and E-scooters and other larger EV beside skates!)
  • even could add an output for siren (simple ADC to a FET to pass through bat voltage to the siren :grin::+1:)
