Metr Pro Updates
Hey @rpasichnyk sent some logs a few days back on the support email
When the I upload the record locations data is not uploaded, problema started after I moved the Metr to another board, and even when back to the original it’s not working, settings are set to upload, tried enabling disabling location everywhere possible, updating the app but nothing solved it
Thanks
Looked at your logs and you have GPS accuracy set to 20, this might be issue, change to 0 and try again.
Will do 2day.
My impression about the freezes are related to a low volt battery situation, when I pulled lots of amps.
Could a capacitor help?
Or is this just my phantasy?
My metr froze 2 times since i have it. Everytime i noticed it was shortly after demanding lots of power. Can’t reproduce it though. Been riding some steep hills lately, metr didn’t give damn about that. So not sure if thats really the reason.
Thanks, could it be, these last few day GPS reception has been worse for some reason
If I’m not bellow the set value when starting the record it won’t use it even if it improves during the ride?
Still on Beta8 of fw5.0 but I get the following when I go in the expert tab:
“Signature check failed”
Is there any chance at all to have an app for samsung’s tizen os? All their smartwatches run on it and they seem to have somewhat addressed compatibility issues with oneui 1+
Metr app update is coming to address this. Earlier betas of fw5.0 have different signature, you can downgrade or wait for update.
@rpasichnyk Is it normal that I can connect to my Metr Pro from my computer without entering the password code on it? That seems like a security flaw, someone could change my settings while I’m at a stop light lol…
No, you can’t do that. Maybe you have already entered the password?
On my phone, yes, but 100% not on my computer.
And you can use VESC Tool without any issues?
yep, just upgraded to FW5 and did all my detections :smiley:
Metr FW is 5.4
What OS on your computer?
Arch Linux, Gnome bluetooth stack. It usually asks for codes for keyboards and stuff, surprised it didn’t for the metr. (We should take this to PMs maybe, but I’m going out for a ride rn :slight_smile: )
Will test that one when I have a chance
Not sure if anyone has raised this complaint before. On mobile, when viewing an uploaded log, it is very hard to navigate through the data accurately, because both the cursor line and the data graph move when I touch and drag.
I think it would be much more intuitive if it worked like it does in the app, where the cursor does not move, and you scroll through the data by moving the graph to line up with the stationary cursor.
Not sure if that explanation makes sense. Anyone else have this problem?
v5.4 seems not to freeze
I know what you mean. Especially at the beginning or the end when it doesn’t scroll anymore and tapping is the only (in this case fairly inaccurate) way to get to a certain spot.
Yep this exactly.
