I know i had the phone in my hand the first 3-4 minutes of the ride (fast switching mode if the police is somewhere) but then i put it in my pocket. Screen turns off after 2 minutes. I pulled the phone out to check the data 8km later, not sure what i did in-between.
Just another data point, it was a few months since I used Metr to log rides, but also had connection drops, nothing has changed, riding the same places as before, far from interference and still got disconnected
The last record I had before that was on Christmas, more than 4 hours long through the middle of a big city and had no problem then
Each record is limited by 50000 points. By default distance between points is 160ms. You can lower it to get more details (with Metr Pro you can go as low as 80ms) or increase it to record longer records. Magic tab -> Point interval
I really donât mind all your input And since you are a heavy metr user, you will get Metr Pro firmware update now. Similar to what FW5.0 UNITY users are testing. Click on blue gear and update, thanks!
Got it. Would the Auto pause feature for the recording âincreaseâ the recording too because it wonât have to write data when doing a break = leaving more space for the actual ride. Or does it automatically stop writing anyway if no data (standstill) is registered.
Either the watch app on your phone or you can also force press the screen on your watch. You have to place it on the one of the corners while using the âInfographâ watch face . Also that particular look for it is with WatchOS 5 and up with the Series 4 & 5.
Also I am so sad I canât use this yet until my Metr arrives. It wonât be for a while.
