Metr Pro Updates
Awesome. Very curious to know what the bug was?
The bug was, when you have the app running all the time connected to the same module, it wont reset Today Stats. If the app was force closed and opened the next day instead, the stats would reset.
I know and I did but Jeff will make the deadzone setting available in the unity app so I hope metr does the same.
@rpasichnyk roman where do you input voltage smoothing setting in latest update?
Thanks
Settings -> Battery
Just noticed…the old modules still Work perfectly fine… I have a Android one phone, with newest fw, and no problems using the old modules with the Metr app
Really good to know I didnt even bother trying my old module :slight_smile:
Also works on iOS and Xmatic app
Sorry that I mixed motor and ESC temps up. Looked to quick.
I would guess its a problem with the Unity hardware then. Don’t see why it would receive these wrong values over UART when the STM32 of the UNITY isn’t actually reading these values.
Do you also get these false values testing on the bench? Then you can confirm its the Unity when hooking it up to the PC over USB.
Thanks for your reply!
Will test it on the bench when I get home. Seems this readings occur when the board is idle. Could this be caused by some kind of interference with the module? Shall I try and move the module around to see if it makes a difference?
thanks - I have a Flipsky dual 6 vesc and the indicated battery voltage fluctuates constantly +/- 0.5V around what it actually is! . Tried turning input voltage smoothing on the metr app - but indicated voltage still fluctuates. Is there a setting for degree of smoothing? or will the vesc always win due to updates etc. Really wish Flipsky would fix this up ! Cheers
The voltage smoothing margin was hardcoded to 0.25V max. If your voltage jumps more than that, if will not work. But now I made that configurable too, you will get it with next update
@mishrasubhransu does the app work fine with Today Stats now? :nerd_face:
Yep! Works great! :smiley:
@rpasichnyk, was the problem of average consumption in the uploaded data vs the daily stat differed by 3-4 wh/km. I haven’t checked that recently, was the discrepancy solved?
I have mentioned the problem here before:
Thanks, I will look into that
I suspect, it’s because you might be averaging the consumption values themselves, as opposed to dividing the total-wh by the total-distance.
Instantaneous consumption can be really high if you are using active braking to stay on incline. Combine that with bigger time step for computing average, bam, you have a higher value for average consumption.
I have also noticed this before. Don’t know which value is correct.
@mishrasubhransu fixed that now (in the browser) The exact post you were referring to now has avg consumption 17Wh/km :nerd_face: The value is now calculated by dividing total Wh by distance. Like it should have been from the beginning, I don’t know what I was thinking.
Woohoo.
@rpasichnyk I’m super impressed at how quick you get these things fixed :smile:
Roman -great -the Flipsky dual6 vesc indicated dc input is pretty symmetrical so smoothing should be great for real time display.
Will the Wh//km work off the smoothed voltage or raw voltage from vesc?
looking forward to the metr update to fix this.
btw -Flipsky have no idea how to resolve this?
Cheers
