You can always flash a custom ROM.
Personally, I believe this isnāt necessary, but Everything in esk8 should be tested to failure, and have those numbers publicly available. I donāt care if a part breaks after 3000km, but Iād like to know thatās in itās expected life range before I buy the part.
unfortunately, i have some kind of pre-production model and there isnt any custom ROM that would worked, I have been trying for years
Thatās pretty much impossible. Thereās so much variety in how people ride their board that any test you make you would need to present with a YMMV disclaimer where the YMMV factor can easily be between 0.1x and 10x, which renders the data nearly useless. Thereās on-road/off-road, dry-conditions/wet-conditions, regular/some/no maintenance, calm/aggressive riding style, rider weightā¦ to name just a few parameters that highly affect the lifetime of most esk8 parts.
Any update on this? As it looks like Metr Pro doesnāt support Android 7 and earlier (so you should probably remove the support from the Playstore as it sais Android 6 or newer.)
For me I canāt find cheap Android right now, and iPhone app disconnects 100 times during ride. So unfortunatly the Metr v1.0 module that I have is unusable for iPhone 6s users and Android users with older than Android 7.1
We are joining Jan with his great initiative!
All donations from DAVEGA thread are eligible for 10% discount at metr.at/shop
PM me for discount code.
#StandWithUkraine
I bet if you sell your iPhone you can get 2 decent androids
I would like to buy either metr pro, metr pro can or metr pro unity with only pcb based antennas . Do you know when you will have any available and double checking that it is a minimum order of Ā£135 yeah ? Would that include Shipping ?
Thanx
I have ordered many times and the value was way below 135. I donāt know where did you get that infoā¦
Heās from the UK and some law, I donāt remember which one it was, requires a minimum of 135 GBP for it to be [xxx]
On the metr site - perhaps you donāt live in the UK ? (Lucky you !)
Yes @ xsynatic - Reason is too many idiots live in the UK and they voted for something that sounds like āBreak Shitā
Since Iām flying to the UK on the 19th I can forward your order if you want
Please try updated app v4.15.3, I have fixed server connection issue on Android 7.
I am cleaning up all list views (modes, records, faults, announcements, trackings) and adding multi select / delete / undo. For faults I am also adding menu / Clear all
Woohoo!
can you add an archive option, would be nice to not delete the errors but still have them in an archive
Found a bug with the openloop command.
When i run the command and go to the Homescreen and back, then a few seconds later the metr doubles the current (battery and motor) for one side. Also visible on the notification.
Not sure if it actually doubles the current or if it just shows that it is doubled but doesnāt actually do it, havenāt checked the temps for long enough.
Great find, please send the log file as well!
