Nice, so it’s basically a lottery…you get a decent pack, but never know…I know about Mooch’s testing…been following for a while…also an area of interest as I am an electrical engineer…
Will definitely think twice on my next eskate buy…I wonder if the new Hurricane is coming with the new wonder cells from the nr. 1 cell manufacturer
Or on the other side I am leaning to gear drives a bit…
thinking of picking up the hurricane, initially, i was thinking of putting a stormcore in there, is there a power gain from doing this? Any other swaps that are worth doing?
There is always something to gain if u do a vesc swap on small EV, be it more control over current amps, throttle curve, or even ability to log ur ride. Is it necessary? Not really, but they r nice to have.
Possibly, but that’s up to ur preference after u ride the board as is, and then change things that u don’t quite like.
Can one of you please just comment that the 100A ESC will most likely be close to overkill for the Hurricane, so my desire to just buy+try will be triggered even more??
Be assured, you are not alone my friend. This is nothing to look at, or to talk about. This is wrong beginning with the amount of digits before the ‘A’ already. Must be a mistake. Go on, nothing to see here.
yeah same. I wonder how it compares to the vesc based stuff and it’s settings. The boards I have tried are not really close, maybe at the very low end.
Potato quality screenshots of the Meepo stream where Kieran (briefly) discussed the upcoming Hurricane Bamboo. He showed a prototype battery on a PCB, it looked to be semi-flexible and said it would be in some kind of plastic enclosure rather than the rigid one of the hurricane. He also mentioned how the bamboo would be notably cheaper than the OG Hurricane, and that they were considering using cells from a manufacturer other than Molicel to further reduce cost. He mentioned “top Chinese manufacturers” as the alternative
“Manufacturers”? More than one?
Hopefully Lishen, BAK, or another good brand and the right cells for the current being drawn from them.
Most won’t give P42A-level performance but IMO if the cells aren’t being run really hard then the difference doesn’t have to be big. For most the difference might not even be noticeable (if not stressing the cells).
