Have y’all seen Meepos new gear drives?
What is with esk8 companies and taking photos of black parts on a black background? It feels like they are trying to hide flaws by making it hard to clearly see the products ![]()
I saw these on IG, didn’t realize it was a gear drive. I thought it was a sealed belt drive.
Is that a urethane torque shock absorber?
The internal design was stolen from newbee afaik. I wouldn’t buy them since the “designer” is a fraud.
Looks like it, that was one of the first things I noticed
aesthetics
Its like newbee and jump drive had a bootleg baby.
Sadly they did not post pics of the internals, but I assume its gonna look just like the newbee.
Yep, seems about right
Those almost look straight cut
and steel ![]()
Steel spur gears is great, hope they not only make pinion and idle gears out of steel and the rest of drivetrain made from cheap plastic.
yes
this would be the 2nd time Ethan has his design stolen ![]()
except being straight cut
motor and idle gear is steel, wheel gear is POM, case is anodized aluminium
What was the first?
flipsky gear drive is also a stolen design from Ethan iirc
This makes 0 sense to me…so still loud but in a high pitched dual idler gear kind of way ![]()
Oh no, POM drive gear, on the part that get the most punishments in the drivetrain, now i understand why this design need rubber coupling.
Since when did FS have gears?
from what i heard, its loud af
with 2 idle gear, u have more teeth engagement, load is more distributed, which reduce the chance of it breaking
one year ago: Flipsky gear drive - Street setup
but its no longer available, i wonder why
