Tests came out pretty good on the MBS stock bushings, meaning it’s not worth the effort producing your bushings ?
I don’t think that’s the testing he’s referring to.
I think he’s referring to his testing of Singularity bushings designed and tested by riptide.
I read this to mean that due to the testing success of a single specialized riptide bushing for each truck (singularity bushings) riptide has no reason to look into developing another product with individual toe side and heel side bushings for the M3s
Has Trampa taught us nothing!?
More SKUs, more gooder!
ahhh i totally missed this
. Very interesting read
No, we have developed a single bushing to replace the bushing pair that comes in the Matrix III that greatly increases the usable range of the trucks for a better carve, deeper lean with enhanced agility and stability.
the “unibrow” ![]()
So, the usual
Great , can’t wait for this one !
…probably this has been asked many many times by all enthousiasts here ; when is the ETA ? (estimated time of availability
If all goes well, we can likely produce before ESK8CON 2025.
We are shipping out a couple of Matrix III kits consisting of 2 preload plates, 4 preload screws and 4 bushing shapes in KranK 90a and 93a. With the 4 shapes so you will have 6 asymmetrical combinations to try. Shape A, B, C, and D so listed front / back, combinations as A/B, A/C, A/D, B/C, B/D and C/D.
Are they already on your site ? Or are these for the “volunteers” ? I’ll volunteer to be your European test-bunny !!![]()
These are not on the site yet. Thank you for volunteering but I have 5 already slated for testing
yeah was joking , i’m a broken useless test-bunny anyway…
Can you drop me a email please when these are available ?
I would recommend following this thread as it will be announced here first.
Who makes the best motor mounts and motor clamps for the Matrix III?
I see these, are there others?
https://www.mbs.com/shop/p/16020-mbs-motor-mount-clamp-for-matrix-iii-ea
and
https://www.mbs.com/shop/p/16060-mbs-motor-mount-arm-ea
Radium makes some pretty sweet ones, OOS though.
I see M-boards also has a single component solution:
I have the Radium Matrix 3 mounts. They are works of art and they are super easy to adjust. I put them on my Lacroix a year ago and the mounts have not moved 1mm since I installed them.
If you have a choice, go with the Radium Mounts IMO. You will not be disappointed.
I remember the matrix ii had tolerance issues on exactly where that threaded hole was located on the truck and made it somewhat difficult for some drive systems to work properly without carefully stacking/packing the axle and/or packing pulley off wheel/setting motor pulley off motor.
Not sure how much the tolerances have been tidied up on matrix iii but just something to note.
If the tolerance on the location of those holes along the width of the hanger is good, seems like one of the better ways to attach a mount
@IDEA has several options
