With swapped wires I seems to get both temperatures, but everything else makes no sense.
The speed goes immediatly to 99km/h when i barely touch any trigger (yes even the brakes), and the battery level keeps blinking between no display and full battery as long as i touch a trigger.
Yes, everything is as it should be on the unity side, i get the right values with metr and davega using the same settings, and i did the setup on the remote.
Don’t forget to set the duty cycle current limit start. Pm me if you have more questions on setup. I feel your pain coming from unity fw setup to vesc FW setup.
Something weird I remember, I had connected the fs Vx2 receivers and receiver of the maytech v2 remote (1 uart plug for 2 receivers just for laughs and giggles) and the data on the mt V2 showed data but now that I sold the vx2( took the receiver off ofc) the mt v2 doesn’t show any data…
Im about 20 minutes away from purchasing this remote to replace a failing Vx1 but the phantom accelerations and dropouts have me second guessing. Anyone have luck with the extended range antenna or any other magical bandaid solution?
I’ve been using the v2 in the city for a couple months now without a single issue. I ride in traffic between cars. Although I think the lack of signal issues has something to do with my deck. It’s a haya with 4 layers of 8oz carbon fiber weave. I suspect that the carbon is providing a barrier from rogue signals.
I’ll just say, my antenna is positioned right here, as physically close to my remote as it can be, in a plastic junction box, and it still got choked out by other signals. I can control my board from 100 yards away with no issue but if I go down this one street of back to back bars and tall buildings, it goes bananas.
