Thissss. Take the $$ you got from the TB40 refund and get eboosted’s evo 40 DS. Add a small spacer for your batteries and you will not regret it.
Gotta keep the lines on that Evo.
the battery and makerX esc has arrived! =D
I’ll be making progress this week
Which cells you got in that 12s5p? I got the 30q from samsung but only have 645Wh.
Nice build nevertheless, looking forward for the end result.
21700 4000mah liitokala cells from accrobrandon
Haaa, makes sense then
Finally had time to work on it more after the holidays, relatives coming over, vacation, etc are over.
Started programming the VESC yesterday and I have a few questions. @mishrasubhransu @BillGordon If you guys can help that’d be much appreciated!
(Screenshots of my settings are below)
My current setup:
elofty 58kv direct drives
120mm cloud wheels
makerx dual esc
I want to run it in BLDC mode
They are connected via internal canbus (I think?). It is NOT split ppm
Does this apply in BLDC mode as well? I tried to change the “minimum erpm” from 150 to 4,000 and 10,000 but the motors made screetching sounds and didn’t work. [screenshot 5]. Am I changing the wrong thing?
Does this VESC act like it’s programming two esc’s over canbus? (It seems so from the above tests and it says its over canbus) Do I put 60a or 120a for motor max? [screenshot 3]. I want 60a/-60a max per motor.
right now I am using a temporary RC car remote until I have my VX1 setup later. When I turn the remote off, the motor goes full speed! :o Is there a way to make it “disconnect” at 0% throttle? Or is it a remote/receiver issue and it’ll be fixed when I install the VX1 remote?
Thank you so much for your help. This is alot more technical than programming a single belt 4.12 I did a while ago, and its all getting a bit over my head.
Thanks!
Screenshots:
I highly recommend getting some Riptide bushings. I can’t even begin to stress how much of a difference you’ll feel when carving
That’s on the list of things to get!
How much do you weigh? I might have some spares
155lbs
Yeah, the wrong thing
For BLDC:
For FOC:
Use this to limit the reverse speed, you can calculate it, but it’s easier to just test, start with something low like 1000, if it just stutter it’s too low, increase until the response is smooth
As far as I know only if they are connected over CAN and only when doing the wizard, the individual settings, like the sensorless ERPM you have to change on each VESC, you can just enable CAN forward when programming instead of plugging in the other USB, also the current settings are for each side of the VESC
Thank you so much!!
Where can I do this?
First connect to one the VESCs as usual, the hit scan, select the other VESC and hit the CAN button, and just go programming as usual, don’t forget to always read the settings before changing anything so you don’t mix between VESCs, even more the app part were one side will have your remote and the other will have nothing configured
Thank you!
I’ll try that when I get home tonight
I might have some extras for your weight. At 6 payments of $0.00 you can have them lol, I’ll pm
More updates:
I did everything @Pedrodemio suggested and it seems to work great! Thanks! Theres still a lot of snow outside so I wont be able to do ride tests for a while
I got my VX1 set up and working
with the “current reverse with break” mode I am experiencing this:
(Steps are in chronological order)
@mishrasubhransu is this what we want for DD with hard brakes?
I’m currently thinking about making my own enclosure from folded 1/8"ABS sheet
Pedro did a great job at explaining the steps. I use current mode not “curent with brake” This also allows you to be stop on a downward hill.
if you kept holding “break” on a flat even after you’re stopped, would you end up going backwards? (slowly)
@mishrasubhransu
Only in ‘current smart reverse mode’ but it feels weird, should be the bottom option on the list
ok, ill try all those out in person when all the snow melts
