I got a mount that shifts, it’s a bkb copy I got it off a guy for cheap ages back.
With only one screw for tension and an imperfect fit do you think engine block epoxy could keep it in sturdy place?
PS I got 2 6374s jammed to em
This is awesome
I’m confused as to what it is
Did you reinforce that area?
Honestly it just looks like JBweld slathered on to me
E: me dumb dumb
Mabye he needed to move it?
Yep that’s it.
lol…
okay I think I had too many hard things between the heatsink plate on the enclosure and the deck. I started noticing some cracks in the enclosure around the heatsink today, so to get ahead of it and rectify the enclosure I applied JB weld, the pushed fiberglass cloth into it real good and slathered more JB weld on top. I dont know how these things work but I went all out with what I bought today and I’m hoping it works to quell the small cracks that started to appear.
Let it cure 3 days longer than you think it needs to
Bondo is a two-part epoxy, so I’m pretty sure @longhairedboy’s enclosure on his Rona Roller definitely counts here as “made of JB Weld”
Can I use jb weld as the epoxy for battle hardening
I wanted to try it on my carvons as I have heard they are prone to magnets breaking
You could have used the search button…
Only if all you can see is JB Weld
Come on give me this one
I looked at @Andy87 tutorial on it And he didn’t mention it
But like putting steel in a magnet? Asking for problems so I don’t recommend it
Or you could have looked at Jb Welds description…
Is jb weld magnetic?
I Donte know how much steel content it has?
Go do some reading if you want numbers, but’s it’s a substantial amount
Steel is ferromagnetic even as fine particulates so it will get pulled until it forms an even layer over the magnet, it will make your life hell
No; it has steel in it and will creep over top of the magnets while curing. It’s great for everything else, except for that.
yeah I think this probably counts. Although literally sculpting JB Weld over a form would be the end all be all DIY esk8 feat of godhood. Mine at least has glass fiber fabric in it. Somewhere. Probably not in the best places.
