This I can live with, I’m gonna make you an offer you can’t refuse
Initial Build picture dump.
Enjoy my dump.
[image]
[image]
[image]
[image]
[image]
[image]
[image]
[image]
[image] [image]
Designed some battery PCBs with 2oz copper weight pour:
[image]
[image]
[image]
[image] [image] [image]
Yeah girl.
[image]
[image]
Thicc balance cables. Because.
[image]
[image]
Literally a pound of silicone in this thing. The battery and enclosure become one using the “Sender Skates Silicone Bukake Battery Building Method” aka SSSBBBM™.
[image]
[image]
[image]
[image]
Write-up coming tonight, maybe.
If I stop procrastinating already.
DEEIF
October 23, 2019, 3:01am
#24
I’ve been waiting I kid I kid…
@Kaly would love to get one of those stamped aluminum enclosures bro
Kaly
November 18, 2019, 11:35am
#26
Don’t feel left out, I’ll put this enclosure in the website.
@DerelictRobot I’m stilling the last picture
Thanks! Can you list some dimensions as well?
@Kaly feel free to steal away bud.
In classic form, I’m turning in my homework late.
I finally wrote some words about my terrible board.
DerelictRobot:
Witnessing the coming of LoveChild into this world has been an odd sensation to behold.
Strangers will often stop me while I’m out riding and ask:
"Andrew, what is that gorgeous machine you are so elegantly perched upon and also how are you this handsome? You must work out. "
After sharing a few hair care & workout routine tips (never skip Ankle Day), I continue on my stylish way until this situation inevitably repeats itself in a few minutes.
So needless to say it’s been an adjustment period.
My build methods tend to lean towards minimalism and I feel the pictures do explain the process pretty well, so I’m going to share some observations & lessons learned during the build & riding experience, and how some build decisions panned out vs others.
What Worked:
HyperTrucks - These are a game changer for me. In my mind they are clearly built for street over AT/off road, simply due to their wide stance & design intent focused on higher speed carving. I am still running the softest bushings that came with it (@Arch thinks this is silly), once broken in these have become the very lively - coming from heavy use of spring trucks its nice to still get that with bushing blocks. They are far more responsive than yellow shockblocks on MBS. At high speeds, these trucks are the most stable and give me higher rider confidence than any other channel truck I’ve ridden. I’ve maxed out at 43mph on LoveChild going downhill and stability was not holding me back at any point.
Excessive Silicone Potting of the batteries/internals - So far it’s rock solid, and not a thing has come loose. The board is dead silent from vibration noise; not a single noise from it aside from the tires & motors. Thanks @Sender for sending me off the deep end with this methodology.
DieBieMS - This continues to impress me as an option when you have the space to fit one in. I have these used in 3 boards total now and have come to rely upon them. Minus one minor issue (later), these have worked flawlessly for me. Unity AS switch is jumpered/bypassed and using DieBieMS RollToStart/Power button.
Maytech 6396 190kv Motors - I have a tendency to destroy motors. Ask @torqueboards . The pair I’ve been using showed up to me second hand and a bit beat up, but they continue to perform. I do hear one of them with a bearing starting to go out, but I’d estimate the motors themselves have 4k+ miles on them at this point and have not been treated gently. Well done on these Maytech, the large secondary bell bearing really helps longevity/durability.
Double sided Neoprene Enclosure Seal - I’ve not been careful about keeping this board dry, and have continued to ride it through the PNW Fall/Winter Season (read: Rain). I doubled down on my enclosure seal efforts by sealing inside/outside with electronics grade silicone. Not the prettiest thing up close but really helps create a strong moisture/rain seal in conjunction with 1/2" neoprene on each side of the deck + enclosure buckets. Only opening I have is for power button + XLR charge port.
XLR Charge port - Holy shit. All my builds are getting these moving forward. Unfortunately this makes me charger-compatible with OneWheelers, which makes me feel dirty, but the port standard is very robust, available in IP67/68 outdoor versions, and capable of up to 20amp of current.
What Didn’t Work
DieBieMS Power Button - Ugh. My one gripe/issue with this build is an erratic power button input on my original DieBieMS. I disconnected it and just used RollToStart, but even since it’s been replaced I kind of wish I had just left the power button out of the equation entirely as RollToStart on the DieBieMS works flawlessly for me. Less ports of ingress the better.
Kaly 4.0/5.0 Aluminum Stamped Enclosure - It’s clean and it can hold a ridiculous amount of batteries, but 4 months in and I’ve dented it in multiple places from handling + riding. Not sure how well it will hold up in the long run, overall the aluminum used simply feels too soft/thin.
Belts - These actually work great. They just aren’t perfect for me given how accustomed to gear drives I have become. Luckily there are ways of fixing that sort of thing.
Samsung 30q - Why did I build a 12S9P with 30qs? Because I had excess inventory of them and I’m lazy/pragmatic to a fault at times. I kinda hate 30qs at this point. They sag to an extent, even on 9p config, I am moving on to bigger cells in the future.
At this point I have about 3k miles on LoveChild and I can confidently say it’s become one of my favorite boards of all time. The size and wider stance of the HyperTrucks is very appealing to me, and the 35/35 end angle of the Kaly deck, firmer stiffness, shorter wheelbase, and gas pedals really differentiate it from how a Nazere handles for me. I love the more aggressive snappy response this setup brings, and am excited to see how the build continues to evolve.
Kellag
January 2, 2020, 5:10am
#32
You’re not getting build of the year old man
Skunk
January 2, 2020, 5:13am
#33
Just salty because you can’t build a reliable board
I can’t beat BaeSk8’s Fiver.com Vote Purchasing Power.
Tamatoa
January 2, 2020, 5:56am
#36
I didn’t pay attention that the enclosure was aluminum, is it lined with some kind of coating or isolant material on the inside? Is it heavy?
Kellag
January 2, 2020, 6:06am
#37
pff I got this destructive fat guy riding my Bertha build and he’s ruining it lol
It’s powder coated. That’s another factor- it has flaked off in a few places already. I don’t really mind it aesthetically, my concerns are more structural if it takes a heavy dent, etc.
It’s not heavy; it’s a lighter weight aluminum. Not sure on exact composition but it’s soft enough to have been stamped into shape. I will ask Ernesto next time we chat.
I ended up insulating the inside of the enclosure/outside of the p-groups further with copious amounts of silicone + fishpaper to play it safe.
Look @CiscoV , if Baesk8 is gonna openly beg for votes that’s all you guys, be my guest.
Cute. You guys must really want it.
I’m rooting for you.
CiscoV
January 2, 2020, 3:31pm
#41
To be fair. We got our boy’s back just because we really believe in him. And he’s a heck of a sickass rider too🤘🏼
No hard feelings my teddy bear
That post has been removed by the way
