You can electronically limit your speed with a 12S. The benefit of 12S is less current draw and possibly longer run time
If you need an enclosure on the cheap, checkout https://diyelectricskateboard.com/products/12s2p-enclosure
They aren’t wide enough for the metroboard batteries. Believe me I checked. I want to get one of the thinner ones, and they’re 160mm wide, while these enclosures are less than that, I don’t remember exactly but it wasn’t gonna work
These are also not 160mm I definitely looked into them though
dauuymm $10 enclosures!
Theres also this one that has enough space for a 10s5p:
https://www.aliexpress.com/item/4000150971517.html?spm=a2g0o.productlist.0.0.680c13dawyZLnP&algo_pvid=48558929-d777-47d4-a6f7-bd2331e17b5c&algo_expid=48558929-d777-47d4-a6f7-bd2331e17b5c-7&btsid=d6314f35-e495-45fb-8514-24a3ceadd8c2&ws_ab_test=searchweb0_0,searchweb201602_6,searchweb201603_53
Also not 160mm wide but I appreciate the suggestions
I did a budget build and found (2) 10s3p lg MH1 batteries, 10s6p in parallel and an enclosure for $190 shipped.
How well does that work? They seem kinda sketchy. Is the power output good, because 20A seems low, but 40A seems better.
I did it on another board, two cheap pre built 10s2p batteries in parallel. My real world experience… top speed was approximately 25mph with one battery. The minute I wired them in parallel I was able to hit 32mph. In my mind doubling the capacity increased the ability to sustain the discharge.
My thoughts are the setup I posted will offer more than enough discharge rate for the esc I’m using.
Battery experts can jump in, but that’s what I’ve experienced.
With regards to these batteries. I have no clue how they will work, but if the specs are right I’d say pretty darn good.
With nearly 700wh I’m hoping for some awesome range
oooooooh I might delve in and buy a couple of those, that deal seems very good. gotta be careful they don’t catch fire though. Let me know if they do.
Hi! Where did you get a sunkko spotwelder for under 100euros? The ones I managed to find are much more expensive than that. Thanks!
Bought it 97euro shipping included. It’s a little more expensive now. Took about a week or less to arrive.
#Aliexpress € 103,17 6%OFF | SUNKKO 737G batterie soudeuse par points 1.5kw LED illumination double affichage numérique double impulsion Machine de soudage utilisé 18650 batterie
