This is still in progress. Copied everything from the other forum and will only update this page from now on.
I am currently using a 27" Ownboard deck swap for commuting to uni since that’s all I could fit under the seat. However now I have a space to store and charge it there, so I decided to build one from scratch suited for my needs and wants.
I am planning to keep stuff relatively cheap but still decent, and then replace stuff with the higher quality ones when I can.
To keep things short, I have main 3 requirements:
- Bigger wheels . The current 90mm are very unforgiving for the London suburb roads.
- Range . I was hoping I could get about 25 miles of realistic range on it. I live 22 miles away from uni and sometimes it would be nice to ride the whole way. This means that I can cross out the pneumatics, so I decided to go with Dickyho’s 145mm solid wheels since I should hopefully get better range on them while still making the ride more comfortable than on 90mm wheels. Eventually I am thinking to get the Trampa Gummies since I like the look of them.
- Larger deck . I am not constrained anymore in terms for size, and I would need a big deck for the wheels and batteries.
Parts List:
- Deck : I was thinking to get the Hummie deck, but I couldn’t find any for sale for a while, and I would like having the motor mounted forward so it would be a bit more stealthy (and I wanted to be able to hold it vertically and not have the motor mount hit the ground). I found a local guy who makes custom decks, and he made a deck for me following my designs. I don’t actually like much flex on boards, so it is made from 12ply of canadian maple, so should not have a lot of flex. Here are some renders of the deck (along with a crude model of the trucks, wheels and motor mounts):
It would have a logo laser etched in the middle. Undecided between laser cut black griptape just where the feet are, or clear griptape on the whole deck:
The board will not be uniform, with the front tip being shorter than the rear, to accommodate for the motors.
Wheels: Dickyho’s 145mm solid wheels seemed to have pretty good reviews, and they are pretty cheap, so I ordered them. Worst case scenario, if they are not quite what I want, I can always resell them for a reasonable price, and buy something else (probably Trampa 125mm Gummies).
Trucks and Motor Mounts : I ordered these from dickyho again, since they are the cheapest things on the market, and still seem quite decent quality. All I would need is new bushings and pivot cups since they are not too great, as expected. Since I bought them he came out with a new revision of his mounts, which look even better.
ESC: I’ve been using the Ownboard ESC for a while and it seemed pretty decent, so I decided to get the Dickyho’s ESC, since it was only about £50 including remote and power switch. I will get VESCs eventually, once the board is finished and I’m ready to buy upgrades to it.
Motors : I am using 2x sensored 6354 170kV, again from dickyho, since they are cheap and the right kV for my setup. I am using 15/60 gearing, so I would be aiming at about 25 mph max, which is pretty much perfect for me. The roads here are not good enough to be trying to go faster, and I will not go offroad to justify bigger more expensive motors.
Battery : Originally was planning to go with Lipos, but ended up changing my mind and will build my own battery pack. I got a Boss spot welder, and a Bestech BMS with a switch. Will probably just make the biggest battery that can fit as a double stack with PCBs (so most likely 10S 8P with 30Q cells).
Enclosure : It would be a custom deck, so I will need a custom enclosure. I got a CR10 that sits idle most of the time, so I am planning to make the enclosure out of fibreglass while using a PLA negative mold. There was a Youtube video where someone has done fibreglass parts using 3D printed molds and he achieved impressive results, so I would follow his instructions.
08/04/19:
I received dickyho’s parts, and I am pretty happy with them. First think I noticed is how heavy it turned out to be, the rear truck with wheels, 60T pulleys, motor mounts and motors are 3.9kg, but it does feel pretty high quality. Here are some pics of the rear truck with motors mounted:
Front view:
I will spraypaint the outer circular aluminium piece that holds the pulley black so it would not be as noticeable.
Top view:
Rear view:
I have bought his adjustable crossbar (Ebay number 303033848672), but I found it hard to install, and once installed it is hard to move the motors to adjust the tension. Since my motors are forward mounted, I wanted some cover for them to help against small pebbles and dirt. I designed and printed the following cover which uses the pulley covers and bolts and nuts that come with the trucks:
I printed it out of PLA mainly as a test. When I will have more time I will reprint it out of PETG or ABS.
19/04/19:
New update, the deck mold was done and it is ready to be vacuum pressed.
01/05/19:
The deck is almost done, just needs a few more layers of varnish.
30/05/19:
Due to recent drama I’ve decided to copy my build thread to this page.
The deck was made by Big Aye Skateboards. I still don’t have and haven’t seen the deck in real life. It looks great in pictures and is pretty similar to what I asked for, although I did have some small issues with him. I will probably get my hands on it in 1-2 weeks, when I will also be done with my uni exams.
