That’s right folks, I popped my board-building-cherry last week after about 20 hours of research on this forum and would like to introduce you to my DP board. DP stands for @dickyho & @pjotr47 of course, as you will see that their components make up the board along with the much appreciated technical support from them when I had questions.
Deck: 34” amazon longboard collecting dust
Motor: (2) 6374 170KV Dickyho motors
ESC & Remote: Dickyho
Wheels/Trucks/Mounts/Drive: Dickyho 145 airless AT Wheel Kit
Battery & BMS: Pjotr47 built 10s3p single stack 30Q + 60A smart BMS
3D Printed parts: PETG ESC Enclosure, PETG Pulley cover and motor cover/brace, PETG Front tunnel riser & light attachment, TPU Rear Tunnel Riser, TPU Battery Enclosure. PETG Deck Saver.
I will admit that once I ordered the products for this build, most of my ongoing hours of forum reading and research is focused on my 2nd build, but that is for another post. Dickyho’s prices kept my total build cost around 700 Euros (including shipping and this damn German VAT I’m finding hard to swallow). Some would call this a budget build, but I feel it is more of a gateway drug that opens up my wallet to a new found way to spend money. The goal was to build an entry level board with my son to give him something to play on while I’m on my OW. I’ve owned an Inboard M1 and have had a OW+ for over three years, so I’m not new to eBoards, but now know that another board will be built in the near future.
Here is what I have done so far with this build:
Cut and sanded the board to accommodate the new wheels and wire path
I designed the ESC enclosure and printed it with PETG. I wanted it to also act as a kicktail/foot support.
Had the motors rear mounted, but decided to mount the motors forward to protect them and keep the board more compact, I’m good either way and open to feedback on advantages/disadvantages of what experience has shown to be the best.
Dickyho shipped these motor pully covers with his motor mounts, which work fine, but don’t cover my aesthetic requirements
The Dickyho motor pully cover file here must be for an older motor mount as the holes are not aligned with the holes for the motor mount I have, so I modified the file to align the holes
@VykkuF made a nice motor cover, which also aligned the motors, but this file also must have been for different motor mounts without mounting holes at end. So I adapted the length and hole location on his design.
I created a 8mm riser with a 6mm tunnel. Printed in TPU with 30% infill so far feels strong enough to wrench down on, but also does a good job with vibration dampening.
Front tunnel riser was just a simple way to mount an existing bike light that my boy moves between his scooter and bike I added a tunnel as well for a future wire runs.
I first printed the battery enclosure in PETG, and started with someone else’s design, but ended up with designing my own, which cracked on the first ride with PETG, so now it is TPU and working awesome as the three-piece enclosure flexes with the deck while the battery is velcroed to just the middle piece, so doesn’t experience any flex.
I was wondering if the TPU enclosure would act as its own gasket, and though it has a nice flex to it, there is still too much gap between the screw inserts for comfort. I am currently thinking I’m just going to run silicone caulking around the lip and between the overlaps, so change my mind if you have a better idea for less than $10 bucks.
I’m really satisfied with how this first build turned out, but the board is just too small for me to be comfortable going over 30 km/h and I have not looked into it, but assume the speed controller from Dickyho can not be adjusted for a smoother acceleration compared to its current punchy starts in the fast mode. With that said, the board is the perfect size for me son who mostly rides in slow mode that taps out at 12 km/h while he learns how to control it.
For my next build, I got one of the B-stock Manta decks from @MarkOneBoards for a longer and wider deck. The drop deck gives a nice 25 inch spread for a wider stance, and I like how it can handle my size 12 feet.
Still to do on this build:
- Better grip tape
- Make enclosures water resistant
- Change front tunnel riser from PETG to TPU
- Figure out how to make the pre-programmed fast mode have a smooth acceleration, if possible with this speed controller
- Have my deck saver cut in aluminum
I tried uploading a short clip of my boy riding the board, but either the mp4 format or my permission level did not allow it.
