Thanks man really appreciate the in-depth reply
There’s this mount:
Also a version of DAVEGA with a smaller display made specifically for e-bikes/e-scooters is on my TODO list. It’s still months away though.
What are the dimensions generally, length x width x thickness available for OW and EUC?
Not sure what you’re asking about exactly, but I can give you some dimensions. I posted something here for example: DieBieMS fork: ENNOID-BMS for 6S to 24S battery packs - #190 by Zippy
Thanks! Well that’s more than I could ask! And Plenty of space inside, what do you pack in this, only esc and BMS or also battery? And is there another similar enclosure on other side of the OW to fit more batteries?
This is the battery box, you can see the BMS in the pics and the rest is battery. The controller box on the other side contains the controller. You can see the Pint one in my build thread: Onewheel Pint with Little FOCer build thread (#focfm) The XR one is quite different.
when is v2 dropping
Assuming you live in London you can relax now. They ceased dropping V2 in 1945.
I’ll announce progress on the next version as it happens. Prototypes have been shipped to me. They’ll need to be analyzed on the bench and then field tested. Stay tuned
ok, could you make a vesion with mosfets facing the board and diy heatsink?
current design uses 30 parts to mount the heatsink
I don’t quite understand your request. For one, the regular controller comes with a pre-mounted heatsink. You shouldn’t have to mess with that. If you are referring to the “FM” version, then the rev 2 doesn’t require spacers and such in order to mount the controller to a heat sink or plate.
yes exactly, was it possible to buy the fm without the connector kit? I’ve never seen it in stock anyways. So rev2 will be like the fm?
The idea is still to have an “FM” version as well as a generic version just as before.
ok is the fm version available without the connector kit? how much money do you save without the heatsink assembly? what does fm stand for?
kinda looks like the trampa mkv ngl
wow. You know I think they might be from the same daddy.
Things are looking good for this new rev. It’s more smooth and much more powerful. It’s exceeded my expectations so far in bench testing. Field testing in my ebike will happen soon. Then field testing amongst a few other individuals will happen. I will be pushing for quick feedback
I’ll find another incredibly stupid way to break it if you would like.
The last FOCer held up crazy well with a shit ton of moisture, dirt and vibration and impacts.
@shaman…
Do all the FOCer versions (existing and future) use a latching on/off switch? If yes, is it normally-open or normally-closed?
