We gotta be more organized with the help we give.
reserved 2
Reserved 3
Can confirm
For anyone confused about the L3x leiftech battery.
each side is a 7S3P. if you combine two in parallel it is 7S6P, with degraded 2.2ah cells it might have 12Ah total. test it.
This sounds cool, I actually picked up a leiftech recently for next to nothin with this idea. Got discouraged and distracted when I hit the first few hurdles taking the bitch apart.
here is an easy way to expand the height of the ESC cover. (take heatsink off,weight savings unless using cfocers on leif hs)
jk don’t do it that way. I made a wooden spacer later worked more properly. The impacts and vibration + lack of compression ruined all those lipos packs however. Well the ones without heat shrink for sure…
Bumping so I will force myself to make a dead simple wiring diagram.
Great example. Budget Flipsky is a good match due to low power motors and belts.
