So I’m putting this here because I believe there is merit to this approach but since I’m just hacking away in my garage, maybe someone else has a better way. I’d like to create discussion around this topic, so please chime in with any experience you have.
I lurked for a long time here and other places before I charged headlong into battery making. I have professional experience with electronics, specifically running them in the ocean, down to depths of up to several hundred meters. After soaking up what information I could find, I decided I would try and route the balance leads off the board and be rid of the onboard BMS altogether.
I’m not going to cover the actual battery building here, but other threads have done better than I ever could.
https://endless-sphere.com/forums/viewtopic.php?f=14&t=68005
Parts:
40 30q’s (±$150, depending on market conditions)
7 Pin waterproof connectors male/female panel mount ($35 or less/pair)
10 ft 12g silicone wire series connections, discharge leads ($11/10ft red+ 10 ft black shipped)
10 ft nickel strip ($5 shipped)
14g charge leads ($5)
20g silicone wire balance leads ($14/20’ spool)
JST 2.0 connector and crimps ($35/kit)
Adhesive Heat shrink tubing, assorted ($15/box, enough for several more projects)
60/40 electrical flux core solder ($10/spool)
Fish paper ($10)
Total just under $300 if it’s your first battery, after buying the spot welder and the soldering iron. I had some of this stuff already, so actual cost was lower.
My first board, I would simply open the enclosure to charge through the JST connector. If you run your boards with lipo packs, you’re probably doing this too. I basically built 2 5s 3p packs and wired them in series for a 10s 3p. I’d have to take it all apart to charge. Not the most elegant, but it worked, and more importantly, I found out that I freaking love commuting on a esk8 and it was very practical way to get around when combined with the trolley system here in San Diego. I present Frankenboard :
The second battery was much more refined in that the balance connections were routed off the board. Basically just routed the balance wires through a waterproof 7pin plug. I’ll post a link but others have found arguably better or undeniably cheaper plugs.
For this one I routed the balance wires and the leads for the series switched series connection into the deck and out a wooden panel. I did this to keep the enclosure free to pop off whenever I needed to dig into it.
Very scientific way of testing the water resistance of the assembled board.
not done here, but I have some lessons learned if you’ll take my word for it while I salvage my pics
pros
- great way to get more info from the battery pack.
- If you already have a hobby charger, it’s probably cheaper.
- Leaves more room for batteries
- Fewer failure points onboard
cons
- very tricky soldering work involved. that middle pin is hard to solder without touching the neighboring pins.
- Relatively inconvient to charge. Either charge one side at a time (safe) or charge both sides at the same time with two separate chargers. Duo chargers do not work, I killed 2.
- The jst end of the charging adapter can be finicky, especially if cheaper wire is used. I’ve had to fix that part every few months for a cable that was made with fake silicone wire. Another one I made for a 12s (2x 6s in series) I made with nice wire and corformalled the crap out of it and it hasn’t broken yet…
more to come
(PSA: save your esk8 pics to the forum before your phone dies on you and takes them all with it
, it’s not a big deal at all. One other thing I like about it… I am a bit OCD. And whenever I’m using a pack with BMS, I always have the concern looming in the back of my mind: Is everything balanced? The way you are doing it, you pretty much always check the balance plug on a multi meter prior to charging. At least I do. And if a cell is a little off…easy fix. I usually just run a balance charge at about .5 amps, and things usually get back in line.
