LACROIX Stormcore ESC and iOS app info
pulling out my old board again today.
it’s been like a year, should i update firmware? i think it’s still running 5.3, not sure.
Motor controller firmware is not a personal computer operating system. Unless you added some hardware thing that isn’t supported, or have some other reason to update it, then you should leave it alone.
Trampa saying they need you to update just because a new version exists you to be an unpaid beta tester risking your own skin and machine for their gain – is definitely NOT a reason to upgrade.
If you need to change the firmware, you will know, and will have a reason. Absent that, the answer is always no.
Is my Stormcore done for? I am getting a DRV fault immediately when I boot my 100D. It was working great until half way through a ride it randomly faulted, and never recovered. It wasn’t even warm. Any ideas? My best guess is vibrations caused something on the board to come loose/stop working.
I mean the firmware or my 100dx was a bit buggy with traction control under heavy breaking, and at the time people were blowing up their 100dxs so the question is really are 100dxs any less shit on a newer firmware not should i try a new firmware just for fun.
That would be a legitimate reason then to try something else, definitely. Just as long as you’re not doing it “because VESC Tool suggested it” or “because it’s old”. But I don’t have 100dx so IDK about that part
i wonder if anyone still has one or they all died.
I had 6.0 on mine. Then again, it just broke, but I don’t really know if I can reccomend it for sure or not. Was working great for awhile though.
Does anyone have any ideas how I could fix it? I’m a little afraid to open it up, but I have a feeling thats what I need to know.
I’d appreciate any help or words of advice! I don’t really want to spend $400 on a new one right now :upside_down_face:
I’m bumping this, once again asking what firmware versions people are successfully running on the 100dx?
I have not upgraded and I’m still getting shaking under heavy breaking. I want to know If I can go above 6.0 without killing it.
Having an issue with one motor kinda hiccuping periodically. Not enough to throw me but check these ah drawn numbers. I switched to a new skp reacher and still getting similar numbers. Anyone have similar experience? Any ideas?
Stormcore 60d+ and skp 6385s 12s7p p42a
Stormcores are on Aliexpress now :open_mouth:
after getting hurt on aliexpress vesc i think im too scared to try
I’m guessing it’s the manufacturer selling off left over stock. There’s 136 available
lol if someone gets one for science… price seems ok… ish
The PCB looks pretty legit. Even includes the NRF module. The caps and fets all check out too, this looks like the real deal.
Pic shows 60d version, not the plus. Wonder if it has the busted uart port and bad thermal readings too.
Lmao the 2nd Pic is a pcb from the 100d+ :rofl:
Doesn’t even specify which in the listing. Scammy scam.
if its as bad as the snes classic clones… i want noooo part :face_vomiting:
Id buy a d100+ today
What’s the difference between 100D, 100D+, and 100DX?
Good, quite good, literal garbage
